Samsung Flip 2 55" Interactive Display - WM55R
Quicklinx: FQ0GWS00 Mfr#: LH55WMRWBGCXEN
£1,683.76 ex VAT
£2,020.51 inc VAT
Samsung Flip provides users with a smooth and familiar pen to paper writing experience in a variety of available colors, styles and widths. Up to 4 people can write simultaneously, using any object as a writing tool. In addition, users can quickly erase the drawings with finger or palm swipe.
On brush mode, Samsung Flip recognizes a wide range of thicknesses, ensuring users can create art at the stroke of a brush. Water and oil painting modes allow different styles and textures, while the Flip also gives users a full, vibrant color palette, even allowing flexible color mixing.
Samsung Flip allows users to write on any background source. By simply clicking the note layer button, users can enjoy smooth writing anytime, anywhere on any content displayed, without affecting any work behind the original layer.
With Samsung Flip, users can quickly and easily select, move, crop, capture, and edit any images. Each Image can also be merged to the roll with just one click of a button, allowing it to be edited or erased.
Samsung Flip has up to 20 pages of writing space per roll, allowing users to seamlessly scroll through pages. In addition, the Flip ensures that confidential meeting information remains in the right hands. Its reinforced lock system allows users to safeguard sensitive content from view.
Users are empowered by the Flip's versatile connection options. USB, HDMI, NFC and screen sharing capabilities enable optimum collaboration and provide interactive content visibility, notation and sharing.
The touch out functionality allows users to sync their personal devices with the Samsung Flip, allowing real-time content sharing and control. Any changes made on the Flip display will be mirrored on the connected device, and vice versa, for efficient collaboration.
Samsung Flip displays all content in clear UHD picture quality, regardless of the room, creating a compelling meeting environment. Backed by the powerful Tizen 5.0 operating system for a seamless user experience, embedded sensors automatically activate the display when the screen is knocked.
Samsung Flip can be used for a wide range of business applications, providing embedded versatile templates. You can use the Flip as a calendar, scheduler, note or checklist board. Samsung Flip perfectly matches any business need, enabling users to utilize the display in various customized ways.
  • Pen mode notation: draw, write and inspire new ideas
  • Brush mode notation. creating a masterpiece
  • Annotation on: write on any background
  • Flexible image editing
  • Easy content navigation and protection
  • Multiple connection options
  • Touch out: synchronized screen viewing
  • Precise visuals with powerful operation
  • Suitable for all business needs
Samsung Flip 2 WM55R WMR Series - 55" LED-backlit LCD display - 4K - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
55"
Commercial Use
Yes - interactive
Platform
Tizen OS
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Frame Rate & Enhancement Technology
60 Hz Refresh Rate
Video Interface
HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN, Bluetooth, NFC
LCD Backlight Technology
LED backlight - New Edge Backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
72% Color Gamut (CIE 1931)
USB
2 passive pens
Voltage
Energy Class
Class A+
154 Watt
Power Consumption (On mode)
80 W
Energy Consumption per Year
117 kWh
129.74 cm x 5.99 cm x 76.82 cm
28.2 kg
Energy Class
Class A+
154 Watt
80 W
117 kWh
Diagonal Class
55"
Commercial Use
Yes - interactive
Combined With
Touchscreen
Series
WMR Series
Platform
Tizen OS
Operating System
Tizen OS 5.0
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
Dimensions
Without stand
129.74 cm
5.99 cm
76.82 cm
28.2 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
60 Hz Refresh Rate
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Flatfrog InGlass Touch Technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
1
Network & Internet Multimedia
Connect & Share
Content Share, Screen Share
Connector Type
2 x HDMI input , USB , Audio line-out , Serial input , LAN
2 passive pens
USB cable
VCCI, C-Tick, GOST, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, IEC 60950-1, EN 60950-1, KC, NOM-019-SCFI-1998, K60950-1, EAC, NOM-001-SCFI-1993 IRAM, RCM, INMETRO, FCC Part 15 Class B, GB 4943.1-2011, KN32, KN35, KCC/EK, CNS 14336-1, VCCI-CISPR 32:2016, AS/NZS CISPR 32:2015, RoHS CNS 15663, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005
Power supply
Input Voltage
Power Consumption Sleep
0.5 Watt
Width (Shipping)
146.4 cm
Depth (Shipping)
19 cm
Height (Shipping)
91.5 cm
Weight (Shipping)
35.2 kg
10 - 80% (non-condensing)
Brand: Samsung
Price Range Ex VAT: £1500+
