Samsung Flip provides users with a smooth and familiar pen to paper writing experience in a variety of available colors, styles and widths. Up to 4 people can write simultaneously, using any object as a writing tool. In addition, users can quickly erase the drawings with finger or palm swipe.
On brush mode, Samsung Flip recognizes a wide range of thicknesses, ensuring users can create art at the stroke of a brush. Water and oil painting modes allow different styles and textures, while the Flip also gives users a full, vibrant color palette, even allowing flexible color mixing.
Samsung Flip allows users to write on any background source. By simply clicking the note layer button, users can enjoy smooth writing anytime, anywhere on any content displayed, without affecting any work behind the original layer.
With Samsung Flip, users can quickly and easily select, move, crop, capture, and edit any images. Each Image can also be merged to the roll with just one click of a button, allowing it to be edited or erased.
Samsung Flip has up to 20 pages of writing space per roll, allowing users to seamlessly scroll through pages. In addition, the Flip ensures that confidential meeting information remains in the right hands. Its reinforced lock system allows users to safeguard sensitive content from view.
Users are empowered by the Flip's versatile connection options. USB, HDMI, NFC and screen sharing capabilities enable optimum collaboration and provide interactive content visibility, notation and sharing.
The touch out functionality allows users to sync their personal devices with the Samsung Flip, allowing real-time content sharing and control. Any changes made on the Flip display will be mirrored on the connected device, and vice versa, for efficient collaboration.
Samsung Flip displays all content in clear UHD picture quality, regardless of the room, creating a compelling meeting environment. Backed by the powerful Tizen 5.0 operating system for a seamless user experience, embedded sensors automatically activate the display when the screen is knocked.
Samsung Flip can be used for a wide range of business applications, providing embedded versatile templates. You can use the Flip as a calendar, scheduler, note or checklist board. Samsung Flip perfectly matches any business need, enabling users to utilize the display in various customized ways.
Pen mode notation: draw, write and inspire new ideas
Samsung Flip provides users with a smooth and familiar pen to paper writing experience in a variety of available colors, styles and widths. Up to 4 people can write simultaneously, using any object as a writing tool. In addition, users can quickly erase the drawings with finger or palm swipe. -
Brush mode notation. creating a masterpiece
On brush mode, Samsung Flip recognizes a wide range of thicknesses, ensuring users can create art at the stroke of a brush. Water and oil painting modes allow different styles and textures, while the Flip also gives users a full, vibrant color palette, even allowing flexible color mixing. -
Annotation on: write on any background
Samsung Flip allows users to write on any background source. By simply clicking the note layer button, users can enjoy smooth writing anytime, anywhere on any content displayed, without affecting any work behind the original layer. -
Flexible image editing
With Samsung Flip, users can quickly and easily select, move, crop, capture, and edit any images. Each Image can also be merged to the roll with just one click of a button, allowing it to be edited or erased. -
Easy content navigation and protection
Samsung Flip has up to 20 pages of writing space per roll, allowing users to seamlessly scroll through pages. In addition, the Flip ensures that confidential meeting information remains in the right hands. Its reinforced lock system allows users to safeguard sensitive content from view. -
Multiple connection options
Users are empowered by the Flip's versatile connection options. USB, HDMI, NFC and screen sharing capabilities enable optimum collaboration and provide interactive content visibility, notation and sharing. -
Touch out: synchronized screen viewing
The touch out functionality allows users to sync their personal devices with the Samsung Flip, allowing real-time content sharing and control. Any changes made on the Flip display will be mirrored on the connected device, and vice versa, for efficient collaboration. -
Precise visuals with powerful operation
Samsung Flip displays all content in clear UHD picture quality, regardless of the room, creating a compelling meeting environment. Backed by the powerful Tizen 5.0 operating system for a seamless user experience, embedded sensors automatically activate the display when the screen is knocked. -
Suitable for all business needs
- Samsung Flip 2 WM55R WMR Series - 55" LED-backlit LCD display - 4K - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 55"
- Commercial Use
- Yes - interactive
- Platform
- Tizen OS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth, NFC
- LCD Backlight Technology
- LED backlight - New Edge Backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Picture Enhancements
- 72% Color Gamut (CIE 1931)
- USB
- Included Accessories
- 2 passive pens
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class A+
- 154 Watt
- Power Consumption (On mode)
- 80 W
- Energy Consumption per Year
- 117 kWh
- Dimensions (WxDxH) - without stand
- 129.74 cm x 5.99 cm x 76.82 cm
- 28.2 kg
- Product Type
- Energy Class
- Class A+
- 154 Watt
- 80 W
- 117 kWh
- Diagonal Class
- 55"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- Series
- WMR Series
- Platform
- Tizen OS
- Operating System
- Tizen OS 5.0
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 2 ports
- Dimensions
- Without stand
- 129.74 cm
- 5.99 cm
- 76.82 cm
- 28.2 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Image Contrast Ratio
- 4000:1
- Brightness
- 350 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- Flatfrog InGlass Touch Technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
- VESA Compatibility
Media Player
- USB Port
- USB Ports Qty
- 1
Network & Internet Multimedia
- Connectivity
- Connect & Share
- Content Share, Screen Share
- Connector Type
- 2 x HDMI input , USB , Audio line-out , Serial input , LAN
- 2 passive pens
- Cables Included
- USB cable
- VCCI, C-Tick, GOST, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, IRAM, IEC 60950-1, EN 60950-1, KC, NOM-019-SCFI-1998, K60950-1, EAC, NOM-001-SCFI-1993 IRAM, RCM, INMETRO, FCC Part 15 Class B, GB 4943.1-2011, KN32, KN35, KCC/EK, CNS 14336-1, VCCI-CISPR 32:2016, AS/NZS CISPR 32:2015, RoHS CNS 15663, GB/T9254-2008, CNS 13438 ITE EMI, ROCT CISPR 24-2013, ROCT CISPR 22:2005
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 146.4 cm
- Depth (Shipping)
- 19 cm
- Height (Shipping)
- 91.5 cm
- Weight (Shipping)
- 35.2 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
