Samsung FIT Plus 512GB USB Flash Drive
Quicklinx: HXZRWS00 Mfr#: MUF-512AB/APC
Hurry, only 3 left in stock!
£42.19 ex VAT
£50.62 inc VAT
The Samsung FIT Plus USB flash drive combines high-capacity storage, fast data transfer speeds, and durability into a compact and stylish package. With a 512 GB capacity, it offers ample space for photos, videos, music, and documents. The drive's USB 3.2 Gen 1 interface delivers fast read speeds of up to 400 MB/s, making it quick and easy to transfer large files. Designed to endure, the Samsung FIT Plus features a robust metal body that's resistant to water, temperature extremes, shocks, and even X-rays and magnets. Its small size and built-in key ring loop make it an ideal choice for professionals and students who need reliable data storage on-the-go.
  • Robust design
    Crafted with a metal body, the Samsung FIT Plus is designed to withstand daily use. Its durability is enhanced by being shock-resistant, temperature-proof, water-resistant, and even X-ray and magnetic-proof, making it suitable for users on-the-go.
  • High-speed performance
    With a USB 3.2 Gen 1 interface, the Samsung FIT Plus offers fast read rates of up to 400 MB/s, allowing for efficient data transfer. This speed ensures that large files can be moved quickly, improving productivity and user experience.
  • Generous storage
    The Samsung FIT Plus provides 256 GB of storage capacity, enabling users to store vast amounts of data, from high-resolution photos and videos to extensive document archives, all in one compact device.
Samsung FIT Plus MUF-512AB - USB flash drive - 512 GB
USB flash drive
Interface Type
USB 3.2 Gen 1
Storage Capacity
512 GB
Enclosure Colour
Software Included
Samsung Magician Software
5-year warranty
USB flash drive
Storage Capacity
512 GB
Enclosure Colour
Read Rate
Up to 400 MB/s
Interface Type
USB 3.2 Gen 1
Magnetic-proof, water resistant, temperature-proof, metal body, key ring loop, shock-resistant, X-ray-resistant
Software Included
Limited warranty - 5 years
23.6 mm
7.3 mm
18.8 mm
3.1 g
60 °C
Brand: Samsung
