Get more mileage with a USB ideal for transfers between ultra-thin PCs and netbooks. Enjoy sleek, super compact design as well as higher transfer speeds and rugged 5-proof durability against water, shock, temp, magnets, and X-rays.
Samsung USB 3.0 flash drive FIT
When form and function come together. The Samsung 3.0 flash drive FIT, features a high-quality, metal-based design for durability, and an incredibly small compact body. Perfect to take in the car, to work, or anywhere you go. With Samsung reliability, you know your data is safe and easily accessible. -
Slim, sophisticated metallic design
With a modern ultra-compact, metal-based design, the Samsung USB 3.0 flash drive FIT offers a professional, streamlined solution to store and protect all of your important data. -
Rugged and reliable 5-proof technology
Samsung reliability safeguards your data. This USB flash drive offers NAND flash technology, and 5-proof technology that makes your memory storage waterproof, shock-proof, temperature proof, magnetic-proof, and X-ray proof. It's all the quality you've come to expect from Samsung. -
High performance
Samsung debuts amazing SuperSpeed USB 3.0 flash drive for fast data transfer and backup with backwards compatibility with USB 2.0.
- Samsung FIT MUF-64BB - USB flash drive - 64 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 64 GB
- Enclosure Colour
- White
- OS Required
- Linux 2.4 or later, Apple MacOS X 10.4 or later, Microsoft Windows 2000/XP/Vista/7/8/8.1, Windows 10
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 64 GB
- Enclosure Colour
- White
- Read Rate
- Up to 130 MB/s
- Write Rate
- Up to 45 MB/s
- Interface Type
- USB 3.0
- Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof
- OS Required
- Limited warranty - 5 years
- 15.44 mm
- 8.7 mm
- 19.67 mm
- 2.6 g
- 0 °C
- 60 °C
