Take high-speed charging technology on the go with the advanced 10200 mAh fast charge battery pack. This battery pack allows you to charge devices compatible with the main high-speed charging standards (Samsung Fast Charge and Qualcomm Quick Charge 2.0) at a much faster rate than traditional USB charging options. Now that support for QC2.0 charging technology has been added to Samsung's Fast Charge battery pack, this product will default to the superfast charging speed for your device. And with a universal USB port output, you can charge other smartphones, tablets or other electronics capable of charging via USB at standard charging rates. The battery pack's 10200 mAh capacity can be recharged over and over.
Quick Charge 2.0 support
Unlike conventional USB charging methods, a Quick Charge 2.0 end-to-end solution takes advantage of higher power levels to quickly and effectively charge devices. -
Pass through charging
Charge the battery pack and a device connected to the battery pack overnight with pass-through charging. When a device is attached to the battery pack and the battery pack is being charged from a power outlet, the device will be charged fully first and then the battery pack will begin to charge.
- Samsung EB-PG935 power bank - USB
- Product Type
- Power bank
- 7.71 cm x 2.3 cm x 10.42 cm
- 290 g
- Black
- Output Connector Type
- USB - on cable: Micro-USB
- Voltage Required
- 5 V
- Voltage Provided
- 5 / 9 V
- Max Electric Current
- 2 A
- Fast Charge Technology
- Qualcomm Quick Charge 2.0
- Battery
- 10200 mAh
- Cables
- Micro-USB cable - 20 cm
- Designed For
- Galaxy S7, S7 edge
- Product Type
- Power bank
- 7.71 cm
- 2.3 cm
- 10.42 cm
- 290 g
- Enclosure Colour
- Black
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Voltage Provided
- 5 / 9 V
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2 A
- LED indicator
- Capacity
- 10200 mAh
- Cables Included
- Designed For
- Samsung Galaxy S7, S7 edge
