Discover the Samsung F32TU870VR monitor, a monitor designed for professionals and enthusiasts alike. This 32-inch monitor brings your content to life with 4K resolution and HDR10 support, offering clarity and detail. With a color gamut that covers 99.9% sRGB, 91.6% DCI-P3, 87.2% NTSC, and 85% Adobe RGB, it delivers accurate and vibrant colors that will make your projects stand out.
The Samsung F32TU870VR is designed for comfort and efficiency. With ergonomic features like height, pivot, swivel, and tilt adjustments, you can easily find the perfect viewing angle. The monitor also simplifies your workspace with connectivity options, including Thunderbolt 3, HDMI, and DisplayPort, along with a built-in USB 3.0 hub for connecting multiple devices.
Enhance your viewing experience with smart features tailored for productivity. Picture-in-Picture and Picture-by-Picture modes allow you to multitask efficiently, while Eye Saver Mode and Flicker-Free technology help reduce eye strain during long work sessions. Whether you're a professional creator, a gamer, or someone who appreciates fine detail and color accuracy, the Samsung F32TU870VR monitor is designed to meet your needs.
- Samsung F32TU870VR - LED monitor - 4K - 32" - HDR
- LED-backlit LCD monitor - 32"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/413719
- Energy Class
- Class G
- Energy Consumption per Year
- 57 kWh
- Power Consumption (On mode)
- 39 W
- Daisy Chaining
- USB 3.0 hub, Ethernet network adapter
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 2500:1 / 100000:1 (dynamic)
- HDR Capable
- HDR10
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1 billion colours
- Colour Gamut
- 85% Adobe RGB (CIE 1931), 87.2% NTSC (CIE 1976), 91.6% DCI-P3 (CIE 1976), 99.9% sRGB (CIE 1931)
- Input Connectors
- 2xThunderbolt 3, HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Dark grey/blue
- 71.62 cm x 22.6 cm x 61 cm
- 8.1 kg
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 57 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Daisy Chaining
- Built-in Devices
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- HDR Format
- HDR10
- Colour Support
- 1 billion colours
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Picture by picture, game mode, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Factory Tunning, Off Timer Plus, Picture-in-Picture
- Dark grey/blue
- 71.62 cm x 22.6 cm x 61 cm - with stand
- 8.1 kg
- DisplayPort 1.2 , HDMI , Headphones , 2 x USB 3.0 , Thunderbolt 3 (power up to 90W) , Thunderbolt 3 (power up to 15W) , Network
Mechanical
- Tilt Angle
- -7/+13
- Swivel Angle
- 90
- Rotation Angle
- -2/+92
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable , 1 x Thunderbolt 3 cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 39 W
- Power Consumption SDR (On mode)
- 39 kWh/1000h
- Power Consumption HDR (On mode)
- 59 kWh/1000h
- Power Consumption (Typical)
- 39 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 71.62 cm - depth: 22.6 cm - height: 61 cm - weight: 8.1 kg , Without stand - width: 71.62 cm - depth: 5.29 cm - height: 42.01 cm - weight: 5.5 kg
- Shipping Width
- 81 cm
- Shipping Depth
- 54.4 cm
- Shipping Height
- 19.2 cm
- Shipping Weight
- 10.6 kg
- Limited warranty - 3 years
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
