Samsung F24T450FQR 24"1920x1080 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: G99VWS00 Mfr#: LF24T450FQRXXU
£99.33 ex VAT
£119.19 inc VAT
The Samsung FT45 Series provides ergonomic features that enhance both all-day comfort and productivity. A fully adjustable stand puts the impressive picture right where you need it, and Eye Saver mode and Flicker Free technology help relieve eyestrain and fatigue. Versatile connectivity simplifies things, with HDMI, DisplayPort and USB. Energy-saving features help reduce power consumption for a cost-effective desktop monitor solution.
Samsung F24T450FQR - T45F Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/405790
Energy Class
Class E
Energy Consumption per Year
22 kWh
Power Consumption (On mode)
15 W
Adaptive-Sync Technology
AMD FreeSync
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Voltage
AC 120/230 V
53.92 cm x 22.4 cm x 37.09 cm
4 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Display Type
Energy Class
Class E
22 kWh
Diagonal Size
24"
AMD FreeSync
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus
53.92 cm x 22.4 cm x 37.09 cm - with stand
4 kg
DisplayPort 1.2 , 2 x HDMI , Headphones , 2 x USB 2.0
Mechanical
Tilt Angle
-3/+25
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
HDMI cable
Input Voltage
AC 120/230 V
15 W
15 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 53.92 cm - depth: 22.4 cm - height: 37.09 cm - weight: 4 kg , Without stand - width: 53.92 cm - depth: 3.94 cm - height: 32.28 cm - weight: 2.6 kg
Shipping Width
60.4 cm
Shipping Depth
14.7 cm
Shipping Height
38.5 cm
Shipping Weight
5.5 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
10 °C
10 - 80% (non-condensing)
Brand: Samsung
