The Samsung EVO Plus microSDXC UHS-I memory card is a versatile and durable storage solution designed to meet the needs of high-demand users. With a generous 1 TB capacity, it provides plenty of space for all your storage needs, from high-resolution images and videos to important documents. Its robust design ensures protection against a wide range of environmental conditions, including water, temperature extremes, and physical impacts, making it an ideal choice for adventurous users. Additionally, the card's high-speed performance, with a read rate of 160 MB/s, supports quick file access and seamless video recording, ensuring efficiency and reliability. Whether you're a professional photographer, a videography enthusiast, or simply looking for a reliable way to expand your device's storage, the Samsung EVO Plus offers a comprehensive solution.
Robust durability
Designed to withstand challenging environments, this microSDXC UHS-I memory card is X-ray-proof, drop-proof, magnetic-proof, temperature-proof, and waterproof, ensuring your data remains safe under various conditions. -
High-speed performance
With a read rate of 160 MB/s, this memory card supports high-speed data transfer, making it suitable for fast-paced applications and smooth video recording in Full HD. -
Expansive storage
Boasting a storage capacity of 1 TB, it offers ample space for high-resolution photographs, videos, and other files, making it a suitable companion for photographers, videographers, and mobile device users seeking extensive storage solutions.
- Samsung EVO Plus MB-MC1T0SA - flash memory card - 1 TB - microSDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 1 TB
- Speed Rating
- A2 / Video Class V30 / UHS-I U3 / Class10
- Technology
- NAND Flash
- Included Memory Adapter
- microSDXC to SD adapter
- 10 years warranty
- Product Type
- Flash memory card
- Storage Capacity
- 1 TB
- Speed Class
- Read Rate
- Up to 160 MB/s
- Form Factor
- Technology
- NAND Flash
- Magnetic-proof, waterproof, X-ray-proof, temperature-proof, drop-proof, wear-resistant
- Limited warranty - flash memory card - 10 years , Limited warranty - adapter - 1 year
- 15 mm
- 11 mm
- Thickness
- 1 mm
- 0.25 g
- -25 °C
- 85 °C
