Samsung ES71 Black Digital Camera
Quicklinx: 786RWS00 Mfr#: EC-ES71ZZBPBGB
  • SDHC Memory Card
Let your Samsung ES71 capture more for you in every picture. Now with wider angle lenses, you can enjoy a wider scope and no longer do you need to miss out on any peripheral detail that once couldn't fit in. So, whether it is amazing scenic views or family reunions...enjoy taking photos that capture the whole story and make reliving great moments more meaningful.
  • Just what you had in mind
    You see the image you want in your head. You point the ES70. And Smart Auto sees it too. This scene recognition technology actually chooses from 16 different settings ranging from landscape to portrait automatically. Then adjusts for the perfect shot. Whether it's catching your friends on a night on the town or a waterfall off a mountain. What you get is exactly what you had in mind. Plus all the credit.
  • When it comes to brightness, it's brilliant
    When we engineered the Samsung ES70 to be bright, we meant it in both senses of the word. It's intelligent and luminous, both. It has a 2.7" LCD for improved contrast and colour reproduction, which allows you to enjoy a wider and clearer image. And its Intelligent LCD brightness auto-matically detects environmental illumination and adjusts the LCD brightness for optimal image viewing. It does the thinking for you, which makes the ES70 a smart choice.
  • VGA quality video. Now in a compact camera
    If you prefer still shots to movies but want to leave your options open the ES70 is right for you. You'll get 640 x 480 quality video at 30 frames per second. You even can use the 5x optical zoom to get up close and vividly personal. And when things get dicey, you can even pause your recording. You'll give up nothing, except carrying around that extra camera.
  • Capture More Of Your Life: 12.2MP, 27mm, 5x
    You already have the eye. Now all you need is the camera to capture the world exactly the way you see it. The ES70 combines a 27mm ultra wide angle lens with a 5x zoom. Letting you can fit more in frame while delivering a deeper perspective. And the 12.2 mega pixels provides the sharp, crisp detail to reveal all kinds of things. Including what a great photographer you are.
  • The camera loves you
    No one has a bad side with ES70's Perfect Portrait system. Sure it fixes red-eye, but this next generation face detection technology even detects blinking. So you're always sure eyes are open and smiles are bright. In addition it evens skin tones, erases blemishes and removes dark circles. And with different level settings, you Can control how much retouching you do. Not that your friends and family need any.
Samsung ES71 - digital camera
Digital camera - compact
Memory Card Slot
SD card
Internal Storage
9.9 MB flash
Sensor Resolution
12.2 Megapixel
Lens System
Zoom lens - 5x zoom - 4.9 - 24.5 mm - f/3.5-5.9
Focus Adjustment
Automatic
Min Focus Distance
80 cm
Digital Zoom
3x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
Li-ion rechargeable battery - 740 mAh (included)
Composite video/audio, USB 2.0
9.6 cm x 2.1 cm x 5.8 cm
119 g
Enclosure Colour
Sensor Resolution
12.2 Megapixel
Optical Sensor Type
CCD
Total Pixels
12,300,000 pixels
Effective Sensor Resolution
12,200,000 pixels
Optical Sensor Size
1/2.33"
ISO (Max)
1600
Optical Zoom
5x
Digital Zoom
3x
Image Stabiliser
Electronic
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO auto
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, text, close-up, backlight, beach/snow, self-portrait, Children, fireworks, night scene, sunset, dawn, beauty shot
Special Effects
Soft, Cool, Negative, Vivid, Custom Effect, normal, Calm, Classic, Forest, Retro
Retouch
Face retouch
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, tungsten light, daylight, fluorescent light (cool white), fluorescent light (daylight)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
8 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
27 - 135mm
Focus Adjustment
Automatic
Min Focus Distance
80 cm
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Built-in lens shield
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.2 m - 2.68 m
Additional Features
Self-Timer Delay
10 sec, 2sec
Additional Features
Audio recording, built-in speaker, auto power save, date/time stamp, sharpness control, digital image rotation, AF lock, cropping an image, resizing an image, saturation control, Scene Detection Technology, in-camera red-eye fix, brightness control, face detection, built-in help guide, Auto Contrast Balance (ACB), Blink Detection technology, Smile Detection technology
Display
2.7" LCD display
Display Format
230,000 pixels
Display Form Factor
Built-in
Display Features
Contrast control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB , Composite video/audio output , DC power input
Software
Software
Drivers & Utilities, Samsung Master
Carrying strap, power adapter, USB cable, audio / video cable
Body Material
Metal
Battery Type
Samsung BP-70A Lithium Ion
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDHC Memory Card, MultiMediaCardplus
Internal Storage
9.9 MB flash
Memory Card
9.9 MB
Image Storage
JPEG 4000 x 3000 , JPEG 3984 x 2656 , JPEG 3968 x 2232 , JPEG 3264 x 2448 , JPEG 2592 x 1944 , JPEG 2048 x 1536 , JPEG 1920 x 1080 , JPEG 1024 x 768
Video Capture
AVI - 640 x 480 - 30 fps , AVI - 640 x 480 - 15 fps , AVI - 320 x 240 - 30 fps , AVI - 320 x 240 - 15 fps
9.6 cm
2.1 cm
5.8 cm
119 g
