Unlike most conventional chargers, this Samsung Wireless Charging pad is both unique and beautiful in design. Its clear, glass-look details and glossy finish add a touch of sophistication, and allows it to fit in well with a variety of interior settings.
Charging your phone is easier than ever with the Samsung Wireless Charger. No need to connect a cable to your smartphone - simply place your mobile device on the charger pad and watch it charge, so easy.
Samsung Wireless Charger helps keeping that minimal clutter-free look easy. It looks great wherever you use it - the living room, the office or the bedroom.
Distinctive design
Unlike most conventional chargers, this Samsung Wireless Charging pad is both unique and beautiful in design. Its clear, glass-look details and glossy finish add a touch of sophistication, and allows it to fit in well with a variety of interior settings. -
Effortless charging
Charging your phone is easier than ever with the Samsung Wireless Charger. No need to connect a cable to your smartphone - simply place your mobile device on the charger pad and watch it charge, so easy. -
Clutter-free convenience
Samsung Wireless Charger helps keeping that minimal clutter-free look easy. It looks great wherever you use it - the living room, the office or the bedroom. -
Perfect match for your Galaxy S6
Samsung Wireless Charger is a great fit with any compatible wireless charging handset The Galaxy S6 and Galaxy S6 Edge is even easier to charge, simply place it on the charger, without any need for additional accessories. Its ambient LED display indicates charging status, turning from a subtle blue to a vibrant green when the battery is full.
- Samsung EP-PG920I wireless charging mat
- Product Type
- Wireless charging mat
- 1.68 cm
- Diameter
- 9.7 cm
- 87.5 g
- Black
- Voltage Required
- 5 V
- Voltage Provided
- 5 V
- Max Electric Current
- 1000 mA
- Designed For
- Galaxy Note5, S6, S6 Active, S6 edge, S6 edge+, S7, S7 edge
- Product Type
- Designed For
- Mobile phone
- 1.68 cm
- Diameter
- 9.7 cm
- 87.5 g
- Enclosure Colour
- Black
- Voltage Required
- 5 V
- Input Connectors
- 5 pin Micro-USB Type B
- Voltage Provided
- 5 V
- 1000 mA
- LED indicator
- WPC, Qi
- Designed For
- Samsung Galaxy Note5, S6, S6 Active, S6 edge, S6 edge+, S7, S7 edge
