Samsung ED75D 75" 1920x1080 VGA DVI HDMI LED Large Format Display
Quicklinx: BKQDWS00 Mfr#: LH75EDDPLGC/EN
  • 1080p
Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
Samsung ED75D ED-D Series - 75" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
75"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Remote control
Voltage
Energy Class
Class B
360 Watt
Power Consumption (On mode)
265 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
387 kWh
167.5 cm x 6.5 cm x 95.85 cm
28.8 kg
Energy Class
Class B
360 Watt
265 W
387 kWh
Diagonal Class
75"
Commercial Use
Series
ED-D Series
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
167.5 cm
6.5 cm
95.85 cm
28.8 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
LED backlight
Multiple Display Control (MDC), LED BLU
Stands & Mounts
Stand
Optional
Remote Control
Remote control
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out , Serial input , Serial output
VGA cable
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
10 - 80% (non-condensing)
