Samsung ED series displays provide viewers with an exciting experience applicable to various scenarios such near-full scale fashion display or clear and legible large-conference display.
- Samsung ED75D ED-D Series - 75" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 75"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 360 Watt
- Power Consumption (On mode)
- 265 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 387 kWh
- Dimensions (WxDxH) - without stand
- 167.5 cm x 6.5 cm x 95.85 cm
- 28.8 kg
- Product Type
- Energy Class
- Class B
- 360 Watt
- 265 W
- 387 kWh
- Diagonal Class
- 75"
- Commercial Use
- Series
- ED-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Dimensions
- Without stand
- 167.5 cm
- 6.5 cm
- 95.85 cm
- 28.8 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LED backlight
- Multiple Display Control (MDC), LED BLU
Stands & Mounts
- Stand
- Optional
Remote Control
- Remote control
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out , Serial input , Serial output
- Cables Included
- VGA cable
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
