The Samsung ED65E Commercial Display is a simple, cost-effective and reliable digital signage solution for your business. It features side connectivity for flexible installation, with DVI, Component and Composite inputs. The large 65" LED screen offers high, full HD image quality, while the 3-year onsite warranty secures your investment and peace of mind.
- Side connectivity opens possibilities for installations with less space
- Enhanced connectivity with DVI, Component and Compostie inputs
- Cost-effective display solution to meet business demands
- 3-year onsite warranty with commercial grade reliability
Captivate your audience with an immersive viewing experience
Entice your audience with crisp, clear FHD images and realistic color on a sleek display with Samsung d-LED technology. A sleek, lightweight design and slim bezels keep your audience focus on your message, helping you capture more business opportunities. The accompanied pivot function gives you the flexibility to display your message vertically or horizontally for the optimal view. -
Affordable startup cost and economical operation
Enjoy all the essential functions of digital signage with affordably priced and energy-efficient Samsung EDE series. With the slim, light weight design, the displays are easy and economical to install, helping to reduce startup cost. Because EDE Series displays require less energy, emit less heat and are durable, they can also help lower your total cost of ownership (TCO).
- Samsung ED65E ED-E Series - 65" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 253 Watt
- Power Consumption (On mode)
- 180 W
- Energy Consumption per Year
- 263 kWh
- Dimensions (WxDxH) - without stand
- 146.74 cm x 5.62 cm x 84.8 cm
- 27.4 kg
- Product Type
- Energy Class
- Class B
- 253 Watt
- 180 W
- 263 kWh
- Diagonal Class
- 65"
- Commercial Use
- Series
- ED-E Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- HDCP Compatible
- Design
- Narrow Bezel Design
- Dimensions
- Without stand
- 146.74 cm
- 5.62 cm
- 84.8 cm
- 27.4 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.744 x 0.744mm
- Response Time
- 6 ms
- Mega Dynamic Contrast Ratio, Optional Touch Overlay
Stands & Mounts
- Stand
- Optional
- Stand Design
- Floor standing
- Flat Panel Mount Interface
- 400 x 400 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- VGA input , DVI-D input , Composite video input , Component video input , HDMI input , Audio line-in , Audio line-out , Serial input , Serial output
- Batteries
- Cables Included
- VGA cable
- CSA, UL, TUV, C-Tick, BSMI, GOST, NEMKO, SASO, CB, CCC, PSB, EK, IRAM, IEC 60950-1, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
- Power Device
- Power supply
- Input Voltage
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
- Width (Shipping)
- 160 cm
- Depth (Shipping)
- 28.7 cm
- Height (Shipping)
- 98 cm
- Weight (Shipping)
- 35.4 kg
- 0 °C
- 40 °C
- 10 - 80%
