Bring home a DVD player that offers better viewing and more functions. With the Samsung E360 DVD Player, you can enjoy movies, music and other content on USB storage. You can also rip your favourite CDs to MP3 without additional hardware or software. Full 1080p Progressive Scan Out playback makes sure you enjoy smooth and clear viewing, and a built-in dust remover helps to deliver perfect playback even when your discs aren't spotless.
Dust Proof
DVD Playback is smooth and uninterrupted thanks to Samsung's dust-proof feature. It actually removes dust particles off of the lens of the DVD player while the disc is rotating. With the player's dust remover in action, you're ensured enhanced performance and a dramatically clearer picture. -
See things clearly with Progressive Scan Out
Everything's twice as real with Progressive Scan Out. It takes a conventional HDTV, with its outdated interlacing method of delivering data, two passes to display what Full HD 1080p's Progressive Scan Out delivers in one. That means you get a smoother, cleaner, better picture that's full of vivid detail – perfect for viewing fast-paced sports and action flicks you love so much. -
Watch movies from your USB
With ConnectShare Movie, simply plug your USB memory drive or HDD into your Blu-ray player and enjoy the content you love. ConnectShare Movie feature reduces the number of devices needed to view, listen and play your favourite content. Play music directly through the speakers of your Blu-ray player and transfer movies and photos to the big screen. Now, experience a wide variety of content from the comfort of your living room. -
CD ripping
Take your favourite tracks with you on your MP3 player. In minutes, you can convert your CDs to MP3s with the CD ripping feature. Extract audio tracks from your CDs simply by inserting your CD and pressing the ripping button.
- Samsung DVD-E360 - DVD player
- Product Type
- DVD player
- 30 cm x 20.8 cm x 4.2 cm
- 1.1 kg
- Media Type
- CD-R, CD-RW, DVD-R, DVD+RW, DVD-RW, DVD+R, DVD, CD
- Media Format
- PAL
- Remote Control
- Remote control - infrared
- Sound Output Mode
- Stereo
- Power
- AC 120/230 V (50/60 Hz)
- Form Factor
- Tabletop
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Product Type
- DVD player
- Form Factor
- Tabletop
- 30 cm
- 20.8 cm
- 4.2 cm
- 1.1 kg
DVD
- Media Type
- Media Format
- PAL
- Media Load Type
- Tray
- Search Speed
- 16x, 32x, 2x, 4x, 8x
- Slow Motion Speed
- 1/8, 1/4, 1/2, 1/16
- Video Formats
- DivX, MPEG-2, MPEG-4
- Audio Formats
- WMA, MP3, LPCM
- Photo Formats
- JPEG
Blu-ray & DVD Features
- Picture Zoom
- Picture Zoom Power
- 3x, 2x, 4x
- Parental Lock
- Progressive scanning, JPEG photo playback, CD ripping
Audio System
- Sound Output Mode
- Stereo
- Digital Audio Format
- Dolby Digital output
- USB host function
Remote Control
- Remote control
- Remote Control Technology
- Infrared
- Connector Type
- Digital audio output (coaxial) (RCA) - rear , USB 2.0 (4 PIN USB Type A) - front , Composite video/audio output (RCA x 3) - rear , SCART (21 PIN SCART) - rear
- Included Accessories
- Video cable
- Cables Included
- 1 x video cable
- ENERGY STAR Certified
- Power Device
- Power supply
- Voltage Required
- 10 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Limited warranty - 1 year
- Width (Shipping)
- 34 cm
- Depth (Shipping)
- 30.3 cm
- Height (Shipping)
- 9.3 cm
- Weight (Shipping)
- 1.3 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
