Samsung's DM82D delivers 24/7 reliability on a large 82" screen for continuous operation. Display content without an external PC thanks to an upgraded Samsung SMART Signage Platform (SSP) and full range of connectivity options. All combined with a sleek industrial design and slim 1.9" chassis depth.
Reliable 24/7 continuous operation
Innovative Samsung cooling technologies allow your message to be displayed with highly reliable 24/7 continuous operation. So business users can meet 24/7 operating requirements in venues ranging from retail stores to Command & Control facilities. -
Enhanced SSP with quad core processor
Experience enhanced System-on-Chip (SoC) performance with a quad core processor. SMART Signage Platform (SSP) is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs. -
Sleek industrial design
Edge-Lit LED technology delivers a sleek industrial design with a 1.9" chassis depth for an elegant look. LED can also slim your TCO thanks to energy efficiency. -
PC-less touch support
The optional touch overlay accessory delivers a cost effective, PC-less touch solution that transforms your display into an interactive whiteboard. Create more collaborative presentations or a dynamic customer experience with tangible results for your business. -
Full connectivity
Discover versatile connectivity options to display a full range of exceptional content that speaks to your audience. Connections include D-Sub, Component, Composite, HDMI, DVI, USB, SD, RS232C/RJ45 and more. -
Built-in Wi-Fi
Expanding your versatility even more, you can enjoy easy media sharing and screen control with built-in Wi-Fi and AllShare Cast. Use AllShare Cast over a Wi-Fi connection for simple content mirroring from a tablet or mobile phone to your display. -
Clean UI design
A user-friendly interface provides an intuitive user experience from changing display settings to installing video walls and managing content schedules and templates. Helping to streamline installation and maintenance, users can effectively coordinate their signage.
- Samsung DM82D DM-D Series - 82" Class (81.5" viewable) LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 82"
- Diagonal Size
- 81.5"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 120Hz Refresh Rate
- Max Number of Screens
- 225
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 2nd Generation
- Speaker System
- 2 speakers
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- Supported Memory Cards
- SD Memory Card
- USB
- 2 ports
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- 363 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 185.42 cm x 4.85 cm x 106.42 cm
- 50 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Product Type
- 363 Watt
- Diagonal Class
- 82"
- Diagonal Size
- 81.5"
- Commercial Use
- Series
- DM-D Series
- Video Processor
- Quad-Core
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 3 ports
- PC Interface
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 185.42 cm
- 4.85 cm
- 106.42 cm
- 50 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Super Clear
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.3135 x 0.9405 mm
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), Certified for 24/7 Continuous Operation, digital daisy chain, Smart Scheduling, e-LED BLU, MagicInfo Player-S2
Video Wall
- 225
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, AVC, H.264, VC-1
- Supported Audio Formats
- AC3, DTS
- Supported Pictures Formats
- JPG, PNG
- SD Memory Card
- USB Port
- USB Ports Qty
- 2
- Configuration
- ARM Cortex-A9 ( 1 GHz ) - 1.5 GB DDR3 - 4 GB
- 4 GB
- Operating System
- Linux
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi, LAN
- Connector Type
- Serial input , Serial output , Remote control/ambient sensor input , Audio line-out , Audio line-in , 2 x USB , DVI-D input , DisplayPort input , 3 x HDMI input , VGA input , DisplayPort output , Composite video / component video / audio input , Remote control output , Multiple Display Control
- Batteries
- Cables Included
- VGA cable
- Plug and Play, CSA, UL, TUV, VCCI, C-Tick, BSMI, GOST, cUL, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, PSB, EK, IRAM, EN 60950-1, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST 22505-97, KN13, KN20, CNS 13438 Class A ITE EMI, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, GOST-R 51317, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Limited warranty - 3 years
- Width (Shipping)
- 200.2 cm
- Depth (Shipping)
- 46.2 cm
- Height (Shipping)
- 123.8 cm
- Weight (Shipping)
- 65 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
