Because of its outstanding durability and performance, DMD series digital signage is the ideal solution for any business or organization whose revenue is dependent on non-stop operation. By leveraging Samsung's proven technology, you can increase sales by continually drawing and informing audiences with rich content delivered on superb-quality digital signage. With highly visible and superior 450-nit brightness, DMD series digital signage keeps viewers engaged in any indoor business environment.
DMD series digital signage is powered by a significantly upgraded embedded SSSP. The industry-leading quad-core SoC processor substantially improves the performance with a remarkably faster processing speed for rich, seamless messaging. The increased power supports interactive digital signage capability. This world's first feature amplifies your messaging with engaging interactivity, without the need for an additional PC. Now, schools, corporations and other businesses can offer interactive signage with less expense and difficulty. In addition, the SSSP supports a picture-in-picture (PIP) size over 50 percent of the digital signage area for operational excellence, compared to less than 50 percent in dual-core digital signage.
Attract audiences 24/7 with powerful professional digital signage
Because of its outstanding durability and performance, DMD series digital signage is the ideal solution for any business or organization whose revenue is dependent on non-stop operation. By leveraging Samsung's proven technology, you can increase sales by continually drawing and informing audiences with rich content delivered on superb-quality digital signage. With highly visible and superior 450-nit brightness, DMD series digital signage keeps viewers engaged in any indoor business environment. -
Simplify content delivery with a hassle-free all-in-one solution
Improve productivity and reduce operating costs by installing and configuring the signage solution with greater ease. The embedded, all-in-one SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO). To boost efficiency, content deployment and sharing is simplified with a PC-less network connection that lets you plug in a USB and link multiple displays over a daisy chain configuration. -
Accelerate business performance with advanced SSSP
DMD series digital signage is powered by a significantly upgraded embedded SSSP. The industry-leading quad-core SoC processor substantially improves the performance with a remarkably faster processing speed for rich, seamless messaging. The increased power supports interactive digital signage capability. This world's first feature amplifies your messaging with engaging interactivity, without the need for an additional PC. Now, schools, corporations and other businesses can offer interactive signage with less expense and difficulty. In addition, the SSSP supports a picture-in-picture (PIP) size over 50 percent of the digital signage area for operational excellence, compared to less than 50 percent in dual-core digital signage. -
Manage digital signage wirelessly anywhere, anytime on a mobile device
DMD series digital signage comes equipped with a Wi-Fi module that enables you to easily transfer, play, share and schedule digital signage content without a physical connection. You no longer have to deal with burdensome cables and connector ports. With mobile app control and content sharing features, you can deploy and manage content from virtually anywhere using a Wi-Fi-equipped smartphone, PC or tablet for maximum flexibility. You can even wirelessly configure and deploy content to digital signage installations using the Wi-Fi module. This feature is ideal in places where cabling is difficult to install. -
Easily manage digital signage with a simplified home UI, tools and templates
Experience intuitive, touch-friendly control of digital signage functions with a home screen UI. Frequently used functions are conveniently available on the home screen in a matrix design represented by large menu buttons for ease of use. A selection of menu configurations is also displayed on the home screen, which can be customized to populate repeatedly used menus instead of using the default selection, for quick access. -
Create a stylish decor with sleek digital signage featuring custom colorization
Enhance the ambiance of your business environment while elevating your brand image with the DMD series digital signage sleek design. The stylish digital signage features ultra-narrow 9.5 mm (0.37-inch) slim bezels that can be installed as options to match any decor. A 49.9 mm (1.97-inch) profile and invisible tag-style logo also ensure that the digital signage perfectly complements your interior design.
- Samsung DM55D DM-D Series - 55" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 55"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Magic Clone, Auto Source Switching & Recovery
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 176 Watt
- Power Consumption (On mode)
- 135 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 197 kWh
- Dimensions (WxDxH) - without stand
- 123.06 cm x 4.99 cm x 70.69 cm
- 15.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class B
- 176 Watt
- 135 W
- 197 kWh
- Diagonal Class
- 55"
- Commercial Use
- Series
- DM-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 123.06 cm
- 4.99 cm
- 70.69 cm
- 15.4 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Super Clear
- Colour Depth
- Up to 1.07 billion colours
- Dynamic Contrast Ratio
- 5000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.21 x 0.63mm
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo, LED BLU, Smart Scheduling
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- SD Memory Card
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Built-in speaker
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out , DisplayPort input , DisplayPort output , USB 2.0
- Cables Included
- VGA cable
- TUV, GOST, cUL, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, UL 60950, CB, CCC, EMC, PSB, EK, IRAM, K60950, NOM-001-SCFI-1993 IRAM, GB 4943.1, IS13252
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 134.8 cm
- Depth (Shipping)
- 14.8 cm
- Height (Shipping)
- 81 cm
- Weight (Shipping)
- 19.5 kg
- 0 °C
- 40 °C
- 10 - 80%
