The Samsung DM48D delivers 24/7 reliability for continuous operation. Create stunning and seamless video walls in Full HD resolution thanks to an upgraded Samsung SMART Signage Platform (SSP) and full range of connectivity options. Combined with a sleek industrial design and slim 2" chassis depth, you can captivate your audience in a moment and leave a lasting impression on the 48" screen.
Reliable 24/7 continuous operation
Samsung cooling technologies allow your message to be displayed with highly reliable 24/7 continuous operation. So business users can meet 24/7 operating requirements in venues ranging from retail stores to command and control facilities. -
Enhanced SSP with quad-core processor
Experience 2x SoC performance thanks to SSP with a quad-core processor. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs. -
Sleek industrial design
Slim-direct LED backlight technology delivers a sleek industrial design with a 2" chassis depth that is combined with a symmetrical 9.5 mm bezel for an elegant look. LED also slims your TCO thanks to up to 50% energy savings over CCFL. -
Full connectivity
Discover versatile connectivity options to display a full range of exceptional content that speaks to your audience. Connections include D-sub, component, composite, HDMI, DVI, USB, SD, RS232C in/out, IR in/out and more. -
Built-in Wi-Fi
Expanding your versatility even more, you can enjoy easy media sharing and screen control with built-in Wi-Fi and AllShare Cast. Use AllShare Cast over a Wi-Fi connection for simple content mirroring from a tablet or mobile phone to your display. -
Clean UI design
A user-friendly interface provides an intuitive user experience from changing display settings to installing video walls and managing content schedules and templates. Helping to streamline installation and maintenance, users can effectively coordinate their signage.
- Samsung DM48D DM-D Series - 48" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 48"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, composite, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Button lock, SMART Signage Platform, Magic Clone, Auto Source Switching & Recovery
- Supported Memory Cards
- SD Memory Card
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- 132 Watt
- Power Consumption (On mode)
- 98 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 143 kWh
- Dimensions (WxDxH) - without stand
- 107.51 cm x 4.99 cm x 61.94 cm
- 11.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Energy Class
- Class B
- 132 Watt
- 98 W
- 143 kWh
- Diagonal Class
- 48"
- Commercial Use
- Series
- DM-D Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- HDCP Compatible
- Dimensions
- Without stand
- 107.51 cm
- 4.99 cm
- 61.94 cm
- 11.1 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Coating
- Super Clear
- Colour Depth
- Up to 1.07 billion colours
- Dynamic Contrast Ratio
- 5000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.183 x 0.549mm
- Response Time
- 8 ms
- Pivot, Multiple Display Control (MDC), digital daisy chain, MagicInfo, LED BLU, Smart Scheduling
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 400 mm
Media Player
- SD Memory Card
Remote Control
- Remote control
Audio System
- Built-in speaker
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out , DisplayPort input , DisplayPort output
- Cables Included
- VGA cable
- TUV, GOST, cUL, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, UL 60950, CB, CCC, EMC, PSB, EK, IRAM, K60950, NOM-001-SCFI-1993 IRAM, GB 4943.1, IS13252
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 118.5 cm
- Depth (Shipping)
- 14.8 cm
- Height (Shipping)
- 71.5 cm
- Weight (Shipping)
- 14 kg
- 0 °C
- 40 °C
- 10 - 80%
