Captivate your audience with stunning, Full HD images and crisp text on Samsung DCE series displays. This digital signage solution gives you the essential functionality you need to easily produce attention-grabbing messages. Its slim, lightweight design makes installation a snap compared with cumbersome conventional displays, saving you needless start-up expenses. The displays feature direct LED BLU technology for rich picture quality, low power consumption and reduced operating costs.
Attract customers with optimized 16/7 performance
Engage customers and vividly display business messaging with Samsung DCE series SMART Signage, featuring high picture quality and reliable 16/7 usage. With a slim, sleek design for extended indoor use in retail stores, small businesses and corporate conference rooms and offices, DCE series displays stunningly present a range of immersive and timely information with captivating picture quality. -
MagicInfo Lite player
MagicInfo Lite player uses a sophisticated technology to play a huge range of content including video, images, photos on demand, or from a schedule. Customers can easily play files from, or transfer between, the large internal memory or external USB devices plugged into the in-built port. -
Control displays in multiple locations easily and instantly
MagicInfo Lite solution that comes with the embedded media player extends the remote content management over network through MagicInfo server. Media contents of the USB memory stick plugged in to the back of the DCE series displays can be scheduled to play from a remote PC. The connection to MagicInfo server also allows remote monitoring and management of the DCE series displays. Device information, content playback schedules, network data monitoring, time scheduling, alarms and various controls are all available remotely even without being in front of the displays. -
Easily manage digital signage with a versatile connectivity
Connect the display to other digital signage easily with interfaces based on your specific needs. The displays provide not only the essential connections businesses use the most but support for a wide range of source device types. Interfaces include HDMI, DVI, D-sub, composite input as well as RJ-45 port for extensive connectivity.
- Samsung DC32E DCE Series - 32" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 32"
- Commercial Use
- Yes - digital signage
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- SMART Signage Platform
- Speaker System
- 1 speaker
- USB
- Included Accessories
- Remote control, batteries
- Energy Class
- Class B
- Power Consumption (On mode)
- 50 W
- Energy Consumption per Year
- 73 kWh
- Dimensions (WxDxH) - without stand
- 72.14 cm x 4.99 cm x 42.03 cm
- 4.8 kg
- Product Type
- Energy Class
- Class B
- 50 W
- 73 kWh
- Diagonal Class
- 32"
- Commercial Use
- Series
- DCE Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 2 ports
- PC Interface
- VGA (HD-15)
- HDCP Compatible
- Modes
- Portrait mode, landscape mode
- Dimensions
- Without stand
- 72.14 cm
- 4.99 cm
- 42.03 cm
- 4.8 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 5000:1
- Brightness
- 330 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Response Time
- 8 ms
- MagicInfo Lite, d-LED BLU, Mega Dynamic Contrast Ratio, Certified for 16/7 Continuous Operation
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 200 x 200 mm
Media Player
- USB Port
- USB Ports Qty
- 1
Remote Control
- Remote control
Audio System
- Speaker System
- 1 speaker
- Output Power / Total
- 10 Watt
- Speakers
- 1 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- Connector Type
- VGA input , LAN , Audio line-in , Audio line-out , 2 x HDMI input , DVI-D input , Composite video input , Remote control , Serial , USB
- Batteries
- Cables Included
- Serial adapter
- Width (Shipping)
- 81.5 cm
- Depth (Shipping)
- 13.2 cm
- Height (Shipping)
- 49.1 cm
- Weight (Shipping)
- 5.9 kg
- 0 °C
- 40 °C
- 10 - 80%
