Samsung DB40D 40" 1920x1080 VGA DVI LED Large Format Display
Quicklinx: 9WX4WS00 Mfr#: LH40DBDPLGC/EN
  • 1080p
The Samsung DB40D delivers advanced display technology in an affordable fashion. Create stunning and seamless video walls in full HD resolution thanks to an upgraded Samsung SMART Signage Platform (SSP) and full range of connectivity options. Combined with a sleek industrial design and slim 2" chassis depth, you can captivate your audience in a moment and leave a lasting impression on the 40" screen.
  • Enhanced SSP with quad core processor
    Experience 2x SoC performance thanks to SSP with a quad core processor. SSP is an integrated, open platform providing a powerful streamlined solution to reduce TCO in digital signage deployments through savings in hardware installation and operating costs.
  • Sleek industrial design
    Slim-direct LED backlight technology delivers a sleek industrial design with a 2" chassis depth that is combined with a symmetrical 10.5 mm bezel for an elegant look. LED also slims your TCO thanks to up to 50% energy savings over CCFL.
  • Wi-Fi Ready
    Ready to expand your versatility even more, you can enjoy easy media sharing and screen control after installing Wi-Fi. Use AllShare Cast over a Wi-Fi connection for simple content mirroring from a tablet or mobile phone to your display.
  • Clean UI design
    A user-friendly interface provides an intuitive user experience from changing display settings to installing video walls and managing content schedules and templates. Helping to streamline installation and maintenance, users can effectively coordinate their signage.
Samsung DB40D DB-D Series - 40" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
40"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Button lock, SMART Signage Platform, Image Rotation, Magic Clone, Auto Source Switching & Recovery, Lamp Error Detection
Supported Memory Cards
SD Memory Card
Remote control
Voltage
Energy Class
Class B
121 Watt
Power Consumption (On mode)
80 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
117 kWh
90.66 cm x 4.99 cm x 52.47 cm
7.5 kg
Environmental Standards
ENERGY STAR Qualified
Energy Class
Class B
121 Watt
80 W
117 kWh
Diagonal Class
40"
Commercial Use
Series
DB-D Series
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Dimensions
Without stand
90.66 cm
4.99 cm
52.47 cm
7.5 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Super Clear
Colour Depth
16.7 million colours
Dynamic Contrast Ratio
5000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.15375 x 0.46125mm
Response Time
8 ms
Commercial Features
Pivot, Multiple Display Control (MDC), MagicInfo, LED BLU, Smart Scheduling
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Media Player
SD Memory Card
Remote Control
Remote control
Audio System
Built-in speaker
Connector Type
VGA input , DVI-D input , HDMI input , Audio line-in , Component video input , Composite video/audio input , Audio line-out
VGA cable
TUV, GOST, cUL, EN 60950, EN55022, NOM, PCBC, SASO, SIQ, IEC 60950, UL 60950, CB, CCC, EMC, PSB, EK, CISPR 13, IRAM, GB 17625.1-2003 EMC, K60950, NOM-001-SCFI-1993 IRAM, GB 4943.1, IS13252
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
100 cm
Depth (Shipping)
12.6 cm
Height (Shipping)
58.5 cm
Weight (Shipping)
9.1 kg
10 - 80%
