Samsung's compact DB10D series displays provide an engaging, personalized customer experience through effective, targeted communication. Exceptionally durable and longlasting, these displays support multiple connectivity and easy content management with Samsung's embedded, all-in-one software solution and built-in media player. The Wide Viewing Angle panel ensures content is visible from the entire room. This allows you to make the most of your limited space in a more creative and impactful way.
Gain reliability and versatility in a professional compact display
DB10D display offers you an array of professional grade features in a compact form factor so that you can easily meet various customer needs. These smaller displays are ideal for delivering customized content to individual customers for a more up-close and personalized experience with the ability to fit into the smallest of spaces and capture viewer attention at eye level. -
Simplify content delivery with a hassle-free all-in-one solution
Improve productivity and reduce operating costs by installing and configuring the signage solution in small spaces with greater ease. The embedded, all-in-one 2nd Generation SSSP eliminates the need for a separate PC or media player to streamline digital signage operation and improve total cost of ownership (TCO). To boost efficiency, content deployment is simplified without a PC by USB plug-and-play. -
Accelerate business performance with advanced 2nd Generation SSSP
DB10D digital signage is powered by a significantly upgraded embedded 2nd Generation SSSP. The quad-core SoC processor substantially improves performance with a remarkably faster processing speed for rich, seamless messaging. In addition, the 2nd Generation SSSP supports a picture-in-picture (PIP) size over 50 percent of the digital signage area for operational excellence, compared to less than 50 percent in dual-core digital signage. -
Manage digital signage wirelessly virtually anywhere, anytime on a mobile device
With a convenient built-in Wi-Fi module, users can control and wirelessly distribute content to the digital signage solution using mobile devices for convenient content management. The ability to send and schedule content from a mobile device, instead of locating a PC that is connected to the digital signage or finding suitable cable connections simplifies display management. -
Easily manage digital signage with a simplified Home UI, tools and templates
Experience intuitive control of digital signage functions with a newly designed Home screen user interface (UI) that can be customized with quick access to frequently used functions and menu configurations. Save time and effort by easily and effectively creating and delivering your message with 100 types of included pre-designed templates that are targeted for various vertical markets. -
Enhance content control capabilities without the need for a separate PC
2nd Generation SSSP with its quad-core, SoC technology provides robust functionality and supports the PC-less DataLink feature which enables you to handle elaborate content management. You can easily retrieve and update content by purchasing a DataLink server and a DataLink extended module without needing a separate SBB or Plug-in Module (PIM). -
Ensure wide visibility of images optimized for location
Samsung has engineered the DB10D display with several features that ensure superb picture quality for maximum impact. Audiences can view the screen clearly from almost anywhere thanks to an extremely wide-viewing angle with a WVA panel. In addition, various picture modes can be used for a variety of environments to the gain the optimal quality for the right location. These include rich color and detailed texture to promote products in a shop or mall, sharp text and video to deliver information and branding in an office or school, plus scheduled changes of time table text and video advertisements for a transportation terminal. -
Control displays in multiple locations easily and instantly
Remotely control Samsung SMART Signage installed in multiple locations from a web server while viewing their current screens in real-time. DB10D's enhanced remote management feature streamlines management and enhances convenience. With MagicInfo server, you can achieve an uncluttered and simplified digital signage configuration that delivers rich media content, enhanced operational efficiency and lower TCO.
- Samsung DB10D DB-D Series - 10" Class (10.1" viewable) LED-backlit LCD display - HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 10"
- Diagonal Size
- 10.1"
- Commercial Use
- Yes - digital signage
- Resolution
- 1280 x 800
- Display Format
- 720p
- Frame Rate & Enhancement Technology
- 60 Hz Refresh Rate
- Max Number of Screens
- 225
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- Wi-Fi
- LCD Backlight Technology
- Edge-lit LED
- TV Tuner
- No tuner
- Commercial Features
- Button lock, Image Rotation, Magic Clone, Auto Source Switching & Recovery, SMART Signage Platform 2nd Generation
- Speaker System
- 1 speaker
- DVR
- Flash - 4 GB
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- Supported Memory Cards
- SD Memory Card
- USB
- Included Accessories
- Remote control, batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class C
- 18.7 Watt
- Power Consumption (On mode)
- 18 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 26 kWh
- Dimensions (WxDxH) - without stand
- 24.68 cm x 2.49 cm x 16.52 cm
- 600 g
- Product Type
- Energy Class
- Class C
- 18.7 Watt
- 18 W
- 26 kWh
- Diagonal Class
- 10"
- Diagonal Size
- 10.1"
- Commercial Use
- Series
- DB-D Series
- Video Processor
- Quad-Core
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Temperature sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- Modes
- Portrait mode
- Dimensions
- Without stand
- 24.68 cm
- 2.49 cm
- 16.52 cm
- 600 g
Display
- Resolution
- 1280 x 800
- Display Format
- 720p
- Edge-lit LED
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 900:1
- Dynamic Contrast Ratio
- 50000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.1695 x 0.1695mm
- Response Time
- 30 ms
- Multiple Display Control (MDC), Smart Scheduling, e-LED BLU, Certified for 16/7 Continuous Operation, MagicInfo Player-S2
Video Wall
- 225
Stands & Mounts
- Flat Panel Mount Interface
- 50 x 50 mm
DVR
- DVR
- Flash - 4 GB
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, AVC, H.264, VC-1
- Supported Audio Formats
- AC3, DTS
- Supported Pictures Formats
- JPG, PNG
- SD Memory Card
- USB Port
- USB Ports Qty
- 1
- Configuration
- ARM Cortex-A9 ( 1 GHz ) - 1 GB DDR3 - 4 GB
- 4 GB
- Operating System
- Linux
Remote Control
- Remote control
Audio System
- Speaker System
- 1 speaker
- Output Power / Total
- 1 Watt
- Speakers
- 1 x main channel speaker - 1 Watt
Network & Internet Multimedia
- Connectivity
- Wi-Fi
- Connector Type
- HDMI input , Serial input , Multiple Display Control , USB 2.0
- Batteries
- Cables Included
- Serial cable
- Plug and Play, CSA, UL, TUV, VCCI, C-Tick, GOST, cUL, DDC-2B, NEMKO, NOM, SASO, CB, AS/NZS 60950-1, CCC, EMC, PSB, EK, IRAM, EN 60950-1, KCC, BSMI CNS 13438, FCC Part 15 B Class A, KC, GB 9254-2008, NOM-019-SCFI-1998, KN22, KN24, K60950-1, cUL No.60950-1, EAC, RCM, IS13252, VCCI V-3/2010.04 Class A, CNS 14972, GOST-R 51317 series, GOST 22505-97, CNS 13439 AV EMI, CNS 14409 AV EMS, GB 17625.1-2012, NOM-001-SCFI-1993, BIS, INMETRO, IEC60950-1, GB 4943.1-2011, AS/NZS CISPR 22:2009, EN 55024:1998+A1:2001+A2:2003, EN 55022:2006+A1:2007
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Width (Shipping)
- 30 cm
- Depth (Shipping)
- 7.9 cm
- Height (Shipping)
- 20.5 cm
- Weight (Shipping)
- 1.2 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
