Grade A Returned
12 months warranty
Excellent condition, showing up to minimal signs of wear which includes, but not limited to, small/fine scratches and marks.
Re-sealed, original packaging
See crystal clear, lifelike colour come to life - Crystal clear, lifelike colour. Whether you're bingeing on a boxset or feasting on a blockbuster, you’ll see everything in crystal clear and lifelike colour. Dynamic Crystal Colour delivers rich and vibrant images in over one billion shades – 64 times more than conventional UHD TVs.
Sound that tracks the action on-screen
A stunningly slim and sleek design - A slim and sleek design. You don’t just want your TV to look good when it's on - you want it to blend into your room when it's off too. This TV has a slim design with a clean cable solution, so it will look stunning from any angle.
- Samsung UE50CU8000K CU8000 Series - 50" LED-backlit LCD TV - Crystal UHD - 4K
- Product Type
- LED-backlit LCD TV - Crystal UHD - Smart TV
- Diagonal Class
- 50"
- Black
- Platform
- Tizen OS
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- HDR Format
- HDR10+
- HDR Technology
- Hybrid Log-Gamma (HLG)
- Frame Rate & Enhancement Technology
- 50 Hz Refresh Rate, Motion Xcelerator
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Connectivity
- Wi-Fi, LAN, Bluetooth
- LCD Backlight Technology
- LED backlight UHD dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-T2
- Internet Streaming Services
- Samsung TV PLUS
- Picture Enhancements
- Mega Contrast, contrast enhancer, Dynamic Crystal Color, One Billion Colour
- Speaker System
- 2 channel
- Platform
- SmartThings
- Intelligent Assistant
- Google Assistant, Alexa, Bixby (not available for some languages and countries)
- USB
- 2 ports
- Included Accessories
- Samsung TM2360E remote control
- Voltage
- AC 220-240 V (50/60 Hz)
- Energy Class
- Class G
- 71 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 111.83 cm x 2.57 cm x 64.46 cm
- 11.5 kg
- Product Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- Power Consumption (Max)
- 140 Watt
- 71 Watt
- Power Consumption SDR (On mode)
- 71 kWh/1000h
- Power Consumption HDR (On mode)
- 124 kWh/1000h
- Diagonal Class
- 50"
- Series
- CU8000 Series
- Model Year
- 2023
- Platform
- Tizen OS
- HDR Capable
- HDR Format
- HDR10+
- HDR Technology
- Video Processor
- Crystal 4K
- TV Tuner
- TV Tuner Presence
- Sensors
- Eco Sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 3 ports
- Modes
- Film Mode, Auto Game Mode, Auto Low Latency Mode (ALLM), Filmmaker Mode, HGIG Mode
- Design
- 3 Bezel-less Design, Slim look, AirSlim design
- Dimensions
- Without stand
- 111.83 cm
- 2.57 cm
- 64.46 cm
- 11.5 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Display Menu Language
- Multilingual
- E-Manual, Wireless TV On, MBR Support, Brightness Detection, Samsung Health, Wireless Dex, Microsoft 365 Cloud, Auto Channel Search, Mobile camera support, Gaming Hub, SlimFit Cam support, Nifty Gateway, Universal Guide, Easy Setup, App Casting
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Black
- Stand Features
- Flat lift
- Flat Panel Mount Interface
- 200 x 200 mm
- VESA Compatibility
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- DVB-C, DVB-T2
- HDTV Tuner
Video Features
- Teletext
- Electronic Programme Guide
- Digital EPG
Media Player
- USB Port
- USB Ports Qty
- 2
Remote Control
- Remote control
- Remote Control Model
- Samsung TM2360E
- Samsung Smart Control included, SolarCell remote
Audio System
- Speaker System
- 2 channel
- Output Power / Total
- 20 Watt
- Bluetooth Audio Streaming, Enhanced Audio Return Channel (eARC), Audio Pre-selection Descriptor, Adaptive Sound, Q-Symphony, Object Tracking Sound Lite, Dual Audio support, Buds Auto Switch
Network & Internet Multimedia
- Functionality
- WEB browsing, Internet video playback
- Connectivity
- LAN Protocol
- Ethernet
- Wi-Fi Protocol
- 802.11ac
- Bluetooth Version
- Bluetooth 5.2
- Connect & Share
- Screen Mirroring, ConnectShare, Smart Hub, Sound Mirroring, Tap View, Media Home
- Samsung TV PLUS
- Supported Consumer Electronics Control (CEC)
- Anynet Plus, Multiroom Link
- Connector Type
- 3 x HDMI , 2 x USB , LAN , Digital audio output (optical)
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- SmartThings
- CEC, HGiG
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Auto On/Off
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 111.83 cm x 2.57 cm x 64.46 cm x 11.5 kg , Panel with stand - 111.83 cm x 22.63 cm x 68.46 cm x 11.8 kg , Stand - 76.36 cm x 22.63 cm
- Width (Shipping)
- 124.6 cm
- Depth (Shipping)
- 13.1 cm
- Height (Shipping)
- 76.1 cm
- Weight (Shipping)
- 15.9 kg
