Samsung toner cartridges are specifically designed to use with your Samsung printer. You'll get first-rate print quality with crisp, vibrant output from the first page to the last. They're easy to install, affordable and deliver, sharp, professional results every time you print. Also high-yield toner cartridges decrease cost per print and increases productivity.
NO NOIS
Imagine a printer that operates quietly and allows you to concentrate on other important tasks while it prints. The NO-NOIS engine design means the toner is stored in a fixed cartridge mechanism, eliminating noise and vibration. It also simplifies toner changes - there are no heavy toners to change, just small, easy-to-access toner bottles. -
Unique toner design
Samsung printer cartridges are the smallest and lightest in their class, ideal for personal, small or home office users. -
Genuine quality
Enjoy consistent print results. With Samsung supplies you're virtually guaranteed high quality pages without any defects. -
Security label
Samsung supplies include a color-changing security label that proves they are genuine products. When the label is tilted, the color changes from clear to cyan. Plus, the embossed characters change between red gold and blue when seen from different angles. You can also verify its originality by feeling its texture. -
Easy-to-change toner
No mess. No fuss. Samsung printer cartridges are easy to replace so you can get back to work. Simply follow three easy steps: open the front cabinet, change the cartridge, and close the cabinet. That's all there is to it! -
Standardized cartridge
Each Samsung LaserJet cartridge has been tested to meet ISO (International Organization for Standardization) standards, which makes it easy to compare toner yields from different manufacturers. With Samsung toner cartridges, you can be confident that you're making an informed buying decision. -
Automatic toner monitoring system
Never get stuck on empty again. When toner is running low, the automatic toner monitoring system conveniently notifies you.
- Samsung CLT-R607M - magenta - original - drum kit
- Product Type
- Drum kit
- Printing Technology
- Laser
- Printing Colour
- Magenta
- Yield
- Up to 75000 pages
- Compatible with
- MultiXpress 9250, 9250ND, 9252NA, 9350, 9350ND, 9352NA
Consumable
- Consumable Type
- Drum kit
- Laser
- Magenta
- Yield
- Up to 75000 pages
- Compatible with
- Samsung MultiXpress 9250, 9250ND, 9252NA, 9350, 9350ND, 9352NA
