Samsung CLX9250ND/9350ND Cyan Drum 75K
Quicklinx: 8SPBWS00 Mfr#: CLT-R607C/SEE
Samsung toner cartridge is specifically designed to use with your Samsung printer. You'll get first-rate print quality with crisp, vibrant output from the first page to the last. It is easy to install, affordable and deliver, sharp, professional results every time you print. Also high-yield toner cartridge decreases cost per print and increases productivity.
  • NO NOIS
    Imagine a printer that operates quietly and allows you to concentrate on other important tasks while it prints. The NO-NOIS engine design means the toner is stored in a fixed cartridge mechanism, eliminating noise and vibration.
  • Unique toner design
    Samsung printer cartridge is small and light, ideal for personal, small or home office users.
  • Genuine quality
    Enjoy consistent print results. With Samsung supplies you're virtually guaranteed high quality pages without any defects.
  • Easy-to-change toner
    No mess. No fuss. Samsung printer cartridge is easy to replace so you can get back to work. Simply follow three easy steps: open the front cabinet, change the cartridge, and close the cabinet. That's all there is to it!
  • Automatic toner monitoring system
    Never get stuck on empty again. When toner is running low, the automatic toner monitoring system conveniently notifies you.
Samsung CLT-R607C - cyan - original - drum kit
Drum kit
Printing Technology
Laser
Printing Colour
Cyan
Yield
Up to 75000 pages
Compatible with
MultiXpress 9250, 9250ND, 9252NA, 9350, 9350ND, 9352NA
Consumable
Consumable Type
Drum kit
Printing Technology
Laser
Cyan
Yield
Up to 75000 pages
Compatible with
Samsung MultiXpress 9250, 9250ND, 9252NA, 9350, 9350ND, 9352NA
