Samsung CLX 9352NA A3 Colour Laser Multifunction Printer
CALL YOUR ACCOUNT MANAGER FOR PRICING!
Quicklinx: B31YWS00 Mfr#: CLX-9352NA/SEE
The MultiXpress C9352NA enhance office productivity with faster printing and scanning capabilities, powered by a fully integrated Samsung 1 GHz dual-core processor. Large print and copy jobs are easier to manage, and scanning throughput is increased. The dual-core processor performs printing tasks faster than a conventional processor, enabling employees to focus on core work activities.
Samsung's unique ReCP (Rendering Engine for Clean Page) technology and up to 600 x 600 x 4 bit dpi improve the overall quality and vibrancy of your color printing, ensuring every printout looks perfect. It automatically sharpens the focus of both graphics and text, while solid objects are overlapped to eliminate white gaps.
Samsung polymerized toner produces smaller and more uniform particles than conventional toners. Printouts have crisper lines and intense colors, and pages curl less often. Additionally, the high wax content improves the image gloss and durability, which helps prevent the document from fading.
The combined boards and chips that make up the All-in-One Board help reduce the number of complex parts, decreasing the failure rate. The All-in-One Board assists in controlling overall energy consumption by lowering power requirements. When compared to a conventional board during an internal test, the all-in-one board helped reduce Typical Electricity Consumption (TEC) by up to 44.2 percent. Samsung Instant Fusing System (IFS) technology also helps increase printing and copying speed. In addition, IFS reduces energy use, which further aids in controlling operating costs.
  • Improve performance with twice the power
  • Enjoy quality printouts
  • Prevent document fading with polymerized toner
  • Low power consumption
  • Reduced downtime for maintenance
    Decreased maintenance and installation times help businesses meet deadlines within budget. Toner replacement for the MultiXpres C9352NA printers is designed for ease of use. In addition, users can correct paper jams without the need for a maintenance call. Fewer steps are required to replace high-frequency service items (HFSIs), such as fusers, rollers and image transfer units (ITUs). Fewer maintenance steps means the device is more readily available when users need it.
  • Simplified savings with the touch of a button
    Businesses can lower operating expenses with greater ease using eco mode, an energy-saving feature that helps companies reduce paper and power costs. Based on an internal Samsung test, Samsung MFPs with eco mode outperformed an MFP without eco mode: easy eco driver provides users a preview of a document before printing, which helps reduce wasted printouts. While previewing the document, users can modify its format by removing text and images.
  • LCD control panel that is largest in its printer class
    The color LCD control panel on the MultiXpress C9352NA MFPs is 8.9 inches and is considered one of the largest MFPs in its class. The control panel tilts for convenient viewing of the current job status, following prompts during an operation and setting up menus. Also, LED indicators, such as low paper alerts or a ready-for-use indicator, help users more quickly determine the device status.
  • XOA (Open Architecture Platform)
    Enjoy the freedom of connecting your multifunctional product to your line-of-business applications through the unique Open Architecture Platform (XOA). Based on open standards, XOA allows print solution vendors to create embedded applications that enhance the use of the device's capabilities to improve business processes.
Samsung MultiXpress 9352NA - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
150000 impressions
Max Copying Speed
Up to 35 ppm (mono) / up to 35 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Scanning
600 x 600 dpi
Display
8.9"
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
98 x 148 mm (min) - 320 x 457 mm (max)
Media Type
Envelopes, plain paper, labels, recycled paper, photo paper, bond paper, heavy-weight paper, thin paper, thick paper, card stock
Standard Media Capacity
1140 sheets
Max Media Capacity
3140 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network, save to HDD
67.75 cm x 76.3 cm x 85.36 cm
109.5 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
150000 impressions
Display Diagonal Size
8.9"
Display Features
Touch screen
Standard Memory
1.5 GB 1.5 GB
Hard Disk Drive
320 GB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Copying Features
ID Card Copy, Poster Copy, Clone Copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PostScript 3, PDF 1.7, PCL 6C, PCL 5ce
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
10.5 sec
Scanning
Scan Element
CCD
Optical Resolution
600 x 600 dpi
Interpolated Resolution
4800 x 4800 dpi
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
100 sheets
Min Media Size
98 x 148 mm
Max Media Size
A3
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
1140 sheets
Max Media Capacity
3140 sheets
100 sheets
500 sheets
ADF - 100 sheets , Bypass tray - 100 sheets , Output tray - 500 sheets , 2 x paper cassette - 520 sheets
Speed Details
Printing: up to 35 ppm (A4) - B/W , Printing: up to 35 ppm (Letter A) - B/W , Printing: up to 35 ppm (A4) - colour , Printing: up to 35 ppm (Letter A) - colour , Copying: up to 35 ppm (A4) - B/W , Copying: up to 35 ppm (Letter A) - B/W , Copying: up to 35 ppm (A4) - colour , Copying: up to 35 ppm (Letter A) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Security Protocols & Features
SSL, TLS, IPsec, IP filtering, MAC address filtering
Operating System Support
MS Windows XP, MS Windows Server 2003, Red Hat Enterprise Linux WS 4.0, MS Windows 7, Red Hat Enterprise Linux WS 5.0, SuSE Linux Enterprise Desktop 10, openSUSE 10.2, openSUSE 10.3, openSUSE 11.0, openSUSE 11.1, Ubuntu Linux 7.10, Ubuntu Linux 8.10, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Debian Linux 5.0, Debian Linux 4.0, Ubuntu Linux 6.06, Ubuntu Linux 6.10, Ubuntu Linux 7.04, Ubuntu Linux 8.04, Red Hat Fedora Core 2-10, SuSE Linux 9.1, OpenSUSE 9.2, OpenSUSE 9.3, OpenSUSE 10.0, Mandrake Linux 10.0, Mandrake Linux 10.1, Mandriva 2005, Mandriva 2006, Mandriva 2007, Mandriva 2008, SuSE Linux Enterprise Desktop 9, Debian Linux 3.1, Windows 8, Apple Mac OS X 10.4 - 10.8, OpenSUSE 10.1, Mandriva 2009
Software Included
Drivers & Utilities
1.1 kW
Power Consumption Sleep
1.5 Watt
First Copy Out Time B/W
7.5 sec
First Copy Out Time Colour
8.5 sec
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (yellow/cyan/magenta)
WHQL, CCC, IPv6 Ready, ISO 15408
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
67.75 cm
76.3 cm
85.36 cm
109.5 kg
Shipping Width
98 cm
Shipping Depth
77 cm
Shipping Height
110 cm
Sound Emission
27 dBA (idle) / 54 dBA (operating)
