Samsung CLX-6250FX A4 Colour All In One Printer/Scanner/Copier/Fax
Quicklinx: 70DJWS00 Mfr#: CLX-6250FX/SEE
If your business demands high performance levels of printing, scanning and copying, then the Samsung 6250FX range is a smart choice. Offering consistently outstanding quality with high resolution and duplex printing, it also minimises operational costs through its Instant Fusing technology. Other conveniences include easy data swapping with Direct USB interface and a power saving mode, making it a very effective and compatible print solution.
  • High resolution
    Communication is key in any business. Colour Print quality can make your company stand out. The SAMSUNG CLX-6220FX / 6250FX range excels in its printing capability by featuring a resolution level of 9600 x 600 dpi and high glossiness level, providing you with consistent professional documents.
  • SAMSUNG Easy Colour Manager
    Easy Colour Manager allows users to easily adjust colour balance, brightness, contrast and saturation of any image that you view on your monitor. It can be especially useful if you have specific colour preferences, or if your company has its own brand requirements.
  • Enhanced Specification
    With a 700MHz CPU and a generous 256MB RAM, the SAMSUNG CLX-6250FX range makes it easy to process, store and handle jobs. The added features and processing power mean it's suitable for the most demanding office environment.
  • Smooth Network Integration
    Conveniently network ready the SAMSUNG CLX-6250FX range is easy to integrate into your IT infrastructure. Future-proof capabilities for the next generation of Internet protocol (IPv6).
  • SAMSUNG's Real-Time Calibration Technology
    SAMSUNG's Real-Time Calibration Technology ensures documents are printed to a consistently high colour quality. However, when dealing with important documents that require special attention, users can choose to manually define the colour quality that will appear on their documents. The enhanced CTD (Colour Toner Density) sensor ensures colour output is always clear, sharp and professional.
Samsung CLX-6250FX - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
80000 impressions
Max Copying Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Copying Resolution
1200 x 600 dpi (colour)
Max Printing Speed
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi
Scanning
600 x 600 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
350 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
170 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, LAN
46.8 cm x 61.5 cm x 49.8 cm
37.4 kg
Microsoft Certification
Compatible with Windows 7
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
80000 impressions
USB 2.0, LAN
Standard Memory
256 MB 256 MB
Max Supported Memory
768 MB 768 MB
Hard Disk Drive
160 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, SPLC
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
4800 x 4800 dpi
Fax Machine
Compatibility
G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Yes (send only)
Fax Machine Features
Automatic redialing
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76 x 127 mm
Max Media Size
A4/Legal
Supported Media Type
350 sheets
100 sheets
170 sheets
ADF - 50 sheets - Legal (216 x 356 mm) , Paper cassette - 250 sheets - Legal (216 x 356 mm) , Output tray - 170 sheets - Legal (216 x 356 mm) , Bypass tray - 100 sheets - Legal (216 x 356 mm)
Speed Details
Printing: up to 24 ppm (A4) - B/W , Printing: up to 25 ppm (Letter A) - B/W , Printing: up to 24 ppm (A4) - colour , Printing: up to 25 ppm (Letter A) - colour , Copying: up to 24 ppm (A4) - B/W , Copying: up to 25 ppm (Letter A) - B/W , Copying: up to 24 ppm (A4) - colour , Copying: up to 25 ppm (Letter A) - colour
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows Server 2003, MS Windows Vista, Apple Mac OS X 10.3 - 10.5
First Copy Out Time B/W
19 sec
First Copy Out Time Colour
19 sec
Supported Windows 7 Features
Windows HD Imaging
46.8 cm
61.5 cm
49.8 cm
37.4 kg
Shipping Width
60 cm
Shipping Depth
65 cm
Shipping Height
93.5 cm
