Samsung CF79 Series C34F791WQU 34" 3440x1440 4ms HDMI DisplayPort LED Curved Monitor
Quicklinx: D5CFWS00 Mfr#: LC34F791WQUXEN
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£605.69 ex VAT
£726.82 inc VAT
Forget about the inconvenience of dual monitors - with the 21:9 ultrawide monitor you can experience truly seamless multitasking on a single screen. For total flexibility, Samsung's Picture-by-Picture (PBP) function lets you connect two input sources using HDMI and DP while maintaining the original image quality.
  • Curved like your eyes for great viewing comfort
    Samsung's 1500R curved screen with the deep curvature is precision engineered to match the natural curvature of your eyes more closely than any other monitor. The deeper curve resulted in reduced eyestrain among viewers compared to flat-screens or other less curved monitors. With Samsung Flicker Free technology and Eye Saver Mode reducing fatigue-inducing blue light emissions, you simply can't get a more comfortable viewing experience.
  • Ultra WQHD for incredible image detail and a wider workspace
    Ultra WQHD enables a screen resolution of 3440 x 1440 - 2.5 times the pixel density of Full HD - that delivers razor-sharp images. The greater pixel density also creates a wider screen workspace, so you see more content at once without much effort scrolling and zooming when web surfing or viewing large files such as spreadsheets.
  • More accurate and life-like colors with Quantum Dot Technology
    Supporting up to 125% sRGB color space, Quantum Dot technology delivers not only more colors than conventional monitors but also colors that are brighter, crisper, and more natural - particularly reds and greens. And because every monitor is factory calibrated, you can be sure you always see the most accurate and life-like images.
  • Excellent 3000:1 contrast ratio and minimal light leakage
    Samsung's advanced VA panel technology minimizes light leakage across the entire screen - right up to the corners - and delivers an excellent 3000:1 contrast ratio for deep blacks.
  • Flawless game play
    Packed with features to satisfy the most dedicated gamers, this premium curved monitor boasts a 100 Hz screen refresh rate for minimal stutter, a 4 ms response time for blur-free action scenes, and AMD Freesync for silky smooth gameplay. And with Game Mode letting you instantly optimize screen brightness and contrast ratios, you'll also enjoy spotting your enemies faster in any kind of game.
  • Unparalleled sophisticated design
    Effortlessly combining function and style, the ultrawide curved screen is bezeless on three sides enhancing its classy figure and seamless viewing. The glossy white rear casing, curving horizontally and vertically, incorporates a hatch to keep cables neatly stowed. And the anti-glare panel is supported on functional swing-and- tilt height adjustable stand that allows precise positioning for enhanced viewing comfort.
  • Built-in speakers and multiple ports for all your entertainment needs
    Dual speakers embedded into the display let you enjoy movies, games, and online content without cluttering your desktop with auxiliary speakers or cables. And 2 HDMI, DP, and 2 USB ports provide a high-performance multiple connection interface that lets you hook up PCs, game consoles, additional monitors, and other devices with ease.
Samsung C34F791WQU - CF79 Series - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
102 kWh
Power Consumption (On mode)
70 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 100 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
White
80.87 cm x 30.94 cm x 51.6 cm
7.6 kg
Display Type
Energy Class
Class C
102 kWh
Diagonal Size
34"
Curved Screen
Yes (1500R)
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Picture in picture, picture by picture, Flicker Free technology, Eye Saver Mode, Quantum Dot Technology, 125% sRGB colour gamut
White
80.87 cm x 30.94 cm x 51.6 cm - with stand
7.6 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphones
Mechanical
Height Adjustment
100 mm
VESA Mounting Interface
1 x HDMI cable , 1 x DisplayPort cable
70 W
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 80.87 cm - depth: 80.87 cm - height: 51.6 cm - weight: 7.6 kg , Without stand - width: 80.87 cm - depth: 16.7 cm - height: 36.28 cm
Diagonal Size: 34in
Response Time: 4ms
Interfaces: HDMI
Brand: Samsung
Price Range Ex VAT: 500 - 750
