Samsung C49J890DKU 49" 3840x1080 4ms HDMI DP USB-C Curved LED Monitor
Quicklinx: DRCRWS00 Mfr#: LC49J890DKUXEN
Work Wider. Work Smarter.
With a feature set as impressive as its 49" super ultra-wide curved screen, Samsung’s revolutionary CJ89 monitor is designed to improve performance in any workplace. So whatever your task, enjoy working smarter with Samsung.
  • Work wider, work smarter
    With a feature set as impressive as its 49" super ultra-wide curved screen, Samsung's revolutionary CJ89 monitor is designed to improve performance in any workplace. So whatever your task, enjoy working smarter with Samsung.
  • See more, do more
    With a screen area equivalent to two 27" monitors side by side, the 32:9 aspect ratio 49" display lets you view and manage multiple projects and windows with ease. And when working with unwieldy spreadsheets, less scrolling and zooming means tasks are completed faster and with fewer errors.
  • Goodbye to dual
    With no bezel blind spots, perfectly matched image quality even from different sources, and fewer cables cluttering your desktop, the CJ89 is the smart alternative to dual monitor setups.
  • Double your view
    Picture-by-Picture lets you display input from two PCs simultaneously for effortless collaboration with colleagues or clients. Simply connect a second device such as a laptop to instantly view its display side by side with your primary PC's display.
  • Built-in KVM switch
    When two devices are connected to the CJ89, its built-in KVM switch lets you control them both using just one keyboard and mouse. multi task more efficiently and save desk space at the same time.
  • Easy setting box
    Easy setting box software makes splitting the monitor workspace into multiple windows a snap. Partition the screen into up to six windows with just a mouse click for an instant view of all your projects. You can also adjust the window sizes for a fully customized view.
  • Fine control
    Fast 144 Hz refresh rateThe rapid 144 Hz screen refresh rate provides flawlessly smooth scene and can be adjustable to 60 Hz/120 Hz for optimized monitor performance.
  • Get connected
    The CJ89 features a wide range of ports, including the newest USB Type-C standard, for compatibility with almost any device. And with Samsung's DeX Station, you can even connect your smartphone for a fully streamlined work flow.
  • Dual USB Type-C ports
    USB Type-C transmits data, video and audio, and power all over a single cable. Connect a smartphone, tablet, or laptop to one of the monitor's two USB Type-C ports to display content onscreen and charge the device at the same time.
  • DeX station
    Samsung DeX station seamlessly integrates your mobile phone into your monitor workspace. Connect the DeX station, dock your phone to display its screen on the monitor and call, message, and manage contacts all using your keyboard.
  • Multiple inputs
    Featuring DP, HDMI, USB and two USB Type-C inputs, the CJ89 lets you connect almost any device you can imagine. And with built-in 7-watt stereo speakers, you can be sure that whatever you, your colleagues, or your clients bring to the table, your monitor is up to the task.
  • Work in comfort
    With technologies to reduce eye fatigue and a fully-featured stand designed to provide optimum viewing, the CJ89 lets you work in greater comfort for increased productivity in the workplace.
  • Curved for comfort
    When you view a flat screen monitor for an extended time, your eyes make small but continual focus shifts that lead to increased fatigue. The CJ89's curved display lets your eyes maintain a constant focus across the entire screen, resulting in less fatigue and a more comfortable viewing experience.
  • Reduced eye fatigue
    Working at a monitor all day causes fatigue. Samsung's eye saver mode reduces fatigue-inducing blue light emissions and its Flicker Free technology suppresses screen flicker, allowing you to work for longer with less strain on your eyes.
  • Optimized view
    The swivel/tilt and height-adjustable stand offers all the flexibility you need to position the screen for maximum comfort. The panel's VESA Standard mount also offers the option of mounting on VESA-compatible arms.
Samsung C49J890DKU - CJ89 Series - LED monitor - curved - 49"
LED-backlit LCD monitor - 49"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/362893
Energy Class
Class G
Energy Consumption per Year
91 kWh
Power Consumption (On mode)
62 W
Curved Screen
KVM Switch, USB 3.0/USB-C hub
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
3840 x 1080 at 144 Hz
Brightness
300 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Voltage
AC 120/230 V
Charcoal black
120.3 cm x 38.16 cm x 52.55 cm
15.1 kg
Display Type
Energy Class
Class G
91 kWh
Diagonal Size
49"
Viewable Size
48.9"
Curved Screen
Yes (1800R)
Built-in Devices
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, picture by picture, Magic Upscale, Flicker Free technology, Image Size, Factory Calibration, Eye Saver Mode, Smart Eco Saving, Off Timer Plus, Custom Key, Picture-in-Picture
Charcoal black
120.3 cm x 38.16 cm x 52.55 cm - with stand
15.1 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
DisplayPort , HDMI , USB-C upstream , USB 3.0 downstream , 2 x USB 2.0 downstream , 2 x USB-C , Headphones
Mechanical
Tilt Angle
-2/+15
Swivel Angle
30
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
DisplayPort cable , USB-C cable
Input Voltage
AC 120/230 V
62 W
62 kWh/1000h
Power Consumption (Typical)
220 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 120.3 cm - depth: 38.16 cm - height: 52.55 cm - weight: 15.1 kg , Without stand - width: 120.3 cm - depth: 19.44 cm - height: 36.94 cm - weight: 12 kg
Shipping Width
132 cm
Shipping Depth
47.6 cm
Shipping Height
31.6 cm
Shipping Weight
20.8 kg
10 °C
10 - 80% (non-condensing)
