With a feature set as impressive as its ultra-wide curved screen, Samsung's CJ89 monitor is designed to improve performance in any workplace. So whatever your task, enjoy working smarter with Samsung.
Goodbye to dual
With no bezel blind spots, perfectly matched image quality even from different sources, and fewer cables cluttering your desktop, the CJ89 is the smart alternative to dual monitor setups. -
Double your view
Picture-by-picture lets you display input from two PCs simultaneously for effortless collaboration with colleagues or clients. Simply connect a second device, such as a laptop, to instantly view its display side by side with your primary PC's display. -
Built-in KVM switch
When two devices are connected to the CJ89, its built-in KVM switch lets you control them both using just one keyboard and mouse. Multitask more efficiently and save desk space at the same time. -
Fast refresh rate
The rapid screen refresh rate provides flawlessly smooth scene and can be adjustable to 60Hz/120Hz for optimized monitor performance. -
Multiple inputs
Featuring DP, HDMI, USB and USB Type-C inputs, the CJ89 lets you connect almost any device you can imagine. And with built-in stereo speakers, you can be sure that whatever you, your colleagues, or your clients bring to the table, your monitor is up to the task. -
Curved for comfort
When you view a flat screen monitor for an extended time, your eyes make small but continual focus shifts that lead to increased fatigue. The CJ89's curved display lets your eyes maintain a constant focus across the entire screen, resulting in less fatigue and a more comfortable viewing experience. -
Optimized view
The swivel/tilt and height-adjustable stand offers all the flexibility you need to position the screen for maximum comfort.
- Samsung C43J890DKU - CJ89 Series - LED monitor - curved - 43"
- LED-backlit LCD monitor - 43"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/362888
- Energy Class
- Class G
- Energy Consumption per Year
- 86 kWh
- Power Consumption (On mode)
- 59 W
- Curved Screen
- KVM Switch, USB 3.0/USB-C hub
- Panel Type
- VA
- Aspect Ratio
- 32:10
- Native Resolution
- 3840 x 1200 at 120 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Voltage
- AC 120/230 V
- Dark grey/blue
- 106.27 cm x 31.44 cm x 52.46 cm
- 13 kg
- Display Type
- Energy Class
- Class G
- 86 kWh
- Diagonal Size
- 43"
- Viewable Size
- 43.4"
- Curved Screen
- Yes (1800R)
- Built-in Devices
- Panel Type
- VA
- Aspect Ratio
- 32:10
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, picture by picture, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Factory Tunning, Smart Eco Saving, Off Timer Plus, Custom Key, Picture-in-Picture
- Dark grey/blue
- 106.27 cm x 31.44 cm x 52.46 cm - with stand
- 13 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- DisplayPort , HDMI , USB-C upstream , USB 3.0 downstream , 2 x USB 2.0 downstream , 2 x USB-C , Headphones
Mechanical
- Tilt Angle
- -2/+17
- Swivel Angle
- 30
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- DisplayPort cable , USB-C cable
- Input Voltage
- AC 120/230 V
- 59 W
- Power Consumption SDR (On mode)
- 59 kWh/1000h
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 106.27 cm - depth: 31.44 cm - height: 52.46 cm - weight: 13 kg , Without stand - width: 106.27 cm - depth: 17.44 cm - height: 35.92 cm - weight: 10.2 kg
- Shipping Width
- 114.9 cm
- Shipping Depth
- 44.5 cm
- Shipping Height
- 27.4 cm
- Shipping Weight
- 17.8 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
