Samsung's advanced display delivers richer, more vivid colors bringing movies, sports broadcasts live-streamed gaming and more to life. Multi-coated semiconductor particles ensure long-lasting image quality while Samsung's unique cadmium-free technology is harmless to the environment.
Incredible color expression
Samsung's advanced display delivers richer, more vivid colors bringing movies, sports broadcasts live-streamed gaming and more to life. Multi-coated semiconductor particles ensure long-lasting image quality while Samsung's unique cadmium-free technology is harmless to the environment. -
Flicker free
Samsung's flicker-free technology minimizes distracting screen flicker to let you work and play for longer in greater comfort. -
360º design
The CH711 curved monitor cleverly conceals cables in its rear panel and stand for a stylish look from all sides, while the 3-sided bezeless display enhances its slender profile and offers a seamless viewing experience. -
Smoother gaming
You'll enjoy flawlessly smooth gameplay in any kind of action. And game mode lets you effortlessly select screen settings optimized for different game genres to ensure you see darker areas in more the detail in game scenes.
- Samsung C32H711QEU - CH71 Series - QLED monitor - curved - 32"
- QLED monitor - 32"
- Energy Class
- Class B
- Energy Consumption per Year
- 80 kWh
- Power Consumption (On mode)
- 55 W
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2767 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, Mini DisplayPort
- Tilt
- Voltage
- AC 120/230 V
- White
- 71.25 cm x 27.63 cm x 51.9 cm
- 6.8 kg
- Plug and Play, DDC-2B, EMI, ISO 9241-307 Class 2
- Display Type
- QLED monitor / TFT active matrix
- Energy Class
- Class B
- 80 kWh
- Diagonal Size
- 32"
- Viewable Size
- 31.5"
- Curved Screen
- Yes (1800R)
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2767 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- MagicBright, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Flicker Free technology, Eye Saver Mode, Quantum Dot Technology
- White
- 71.25 cm x 27.63 cm x 51.9 cm - with stand
- 6.8 kg
- HDMI , Mini DisplayPort
Mechanical
- Tilt
- Tilt Angle
- -2/+15
- 360° rotation
- Cables Included
- 1 x HDMI cable
- Input Voltage
- AC 120/230 V
- 55 W
- Power Consumption (Typical)
- 59 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 71.25 cm - depth: 27.63 cm - height: 51.9 cm - weight: 6.8 kg , Without stand - width: 71.25 cm - depth: 6.28 cm - height: 42.07 cm - weight: 5.3 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
