The Samsung BAR Plus USB flash drive combines durability with performance, offering a reliable storage solution for those who value data integrity and speed. With a storage capacity of 512 GB, it meets the needs of users requiring substantial space for their digital content. Its robust metal body is designed to withstand harsh conditions, being resistant to water, shocks, magnets, and X-rays, ensuring your data is protected no matter where you go. The inclusion of a key ring loop adds convenience, making it easy to carry. Furthermore, its USB 3.2 Gen 1 interface provides a read rate of up to 400 MB/s, making file transfers swift and efficient. Whether for professional use, outdoor adventures, or everyday tasks, the Samsung BAR Plus is an excellent choice for secure and speedy data storage.
Robust design
Crafted with a metal body, the Samsung BAR Plus is not only elegant but also durable. Its resistance to water, shocks, magnets, and X-rays ensures your data stays safe in various environments, making it an ideal companion for outdoor activities or challenging work conditions. -
High-speed performance
With a USB 3.2 Gen 1 interface, the Samsung BAR Plus offers a read rate of up to 400 MB/s, allowing for fast data transfer. This speed is essential for moving large files quickly, enhancing productivity and reducing waiting time. -
Generous storage
Boasting a storage capacity of 512 GB, this USB flash drive provides ample space for your photos, videos, music, and documents. It's an excellent solution for users needing significant storage in a compact, portable form.
- Samsung BAR Plus MUF-512BE4 - USB flash drive - 512 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.2 Gen 1
- Storage Capacity
- 512 GB
- Enclosure Colour
- Grey
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 512 GB
- Enclosure Colour
- Grey
- Read Rate
- Up to 400 MB/s
- Interface Type
- USB 3.2 Gen 1
- Magnetic-proof, water resistant, temperature-proof, metal body, key ring loop, shock-resistant, X-ray-resistant
- Limited warranty - 5 years
- 15.46 mm
- 12.02 mm
- 40.05 mm
- 10.9 g
- 0 °C
- 60 °C
