The Samsung BAR Plus USB flash drive offers high-capacity storage, efficient data transfer speeds, and a durable design for a reliable storage solution. With 512 GB of space, it supports extensive file storage needs for photos, videos, music, and documents. The drive's USB 3.2 Gen 1 interface facilitates quick data transfers, with read rates up to 400 MB/s, enabling rapid access to large files. It is designed to withstand daily use, featuring a robust metal body resistant to water, shocks, magnets, and temperature variations, ensuring data safety in various conditions. Its compact form factor, including a key ring loop, allows for easy portability and access to files on-the-go.
                Robust designCrafted with a metal body, the Samsung BAR Plus USB flash drive offers a durable solution for your storage needs. Its resistance to water, shocks, magnets, and temperature variations ensures your data stays safe in various environments
                High-speed transfersExperience swift data transfers with the Samsung BAR Plus, featuring a USB 3.2 Gen 1 interface. With read rates up to 400 MB/s, moving large files is both quick and efficient
                Generous storageWith a storage capacity of 512 GB, this USB flash drive provides ample space for your photos, videos, music, and documents, making it an ideal choice for both personal and professional use
- Samsung BAR Plus MUF-512BE3 - USB flash drive - 512 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.2 Gen 1
- Storage Capacity
- 512 GB
- Enclosure Colour
- Silver
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 512 GB
- Enclosure Colour
- Silver
- Read Rate
- Up to 400 MB/s
- Interface Type
- USB 3.2 Gen 1
- Magnetic-proof, water resistant, temperature-proof, metal body, key ring loop, shock-resistant, X-ray-resistant
- Limited warranty - 5 years
- 15.46 mm
- 12.02 mm
- 40.05 mm
- 10.9 g
- 0 °C
- 60 °C
