Samsung BAR Plus 512GB USB Flash Drive - Champagne Silver
Quicklinx: HXZPWS00 Mfr#: MUF-512BE3/APC
£75.27 ex VAT
£90.32 inc VAT
The Samsung BAR Plus USB flash drive offers high-capacity storage, efficient data transfer speeds, and a durable design for a reliable storage solution. With 512 GB of space, it supports extensive file storage needs for photos, videos, music, and documents. The drive's USB 3.2 Gen 1 interface facilitates quick data transfers, with read rates up to 400 MB/s, enabling rapid access to large files. It is designed to withstand daily use, featuring a robust metal body resistant to water, shocks, magnets, and temperature variations, ensuring data safety in various conditions. Its compact form factor, including a key ring loop, allows for easy portability and access to files on-the-go.
  • Robust design
    Crafted with a metal body, the Samsung BAR Plus USB flash drive offers a durable solution for your storage needs. Its resistance to water, shocks, magnets, and temperature variations ensures your data stays safe in various environments
  • High-speed transfers
    Experience swift data transfers with the Samsung BAR Plus, featuring a USB 3.2 Gen 1 interface. With read rates up to 400 MB/s, moving large files is both quick and efficient
  • Generous storage
    With a storage capacity of 512 GB, this USB flash drive provides ample space for your photos, videos, music, and documents, making it an ideal choice for both personal and professional use
Samsung BAR Plus MUF-512BE3 - USB flash drive - 512 GB
USB flash drive
Interface Type
USB 3.2 Gen 1
Storage Capacity
512 GB
Enclosure Colour
Silver
5-year warranty
USB flash drive
Storage Capacity
512 GB
Enclosure Colour
Silver
Read Rate
Up to 400 MB/s
Interface Type
USB 3.2 Gen 1
Magnetic-proof, water resistant, temperature-proof, metal body, key ring loop, shock-resistant, X-ray-resistant
Limited warranty - 5 years
15.46 mm
12.02 mm
40.05 mm
10.9 g
60 °C
Brand: Samsung
