Get more mileage with a USB, which is ideal for transferring files between PCs and Notebooks. Enjoy the best of both worlds with sleek, super-compact design as well as higher transfer speeds and rugged 5-proof durablity against water, shock, temp, magnets, and X-Rays.
Samsung USB 3.0 flash drive
When form and function come together, the Samsung USB 3.0 Flash Drive features a high quality metal casing for added durability, and a streamlined ergonomic design with a natural feel making it easy to grip and use. You can count on Samsung performance and reliability to keep your data safe and accessible. -
Unique and sophisticated metallic design
A unique, sophisticated design, the sleek Samsung USB drive is an appealing combination of form and performance. This streamlined metallic-based design appeals to your aesthetic side, while the larger key ring hole is practical and can prevent it from being lost. -
Rugged and reliable 5 proof technology
Samsung reliability safeguards your data. The USB flash drive offers NAND flash technology and 5-proof technology that makes your memory storage water proof, shock proof, temp proof, magnetic proof, and X-Ray proof. It's all the quality you've come to expect from Samsung, the trusted name for memory. -
High performance
The flash drive for the future. Staying ahead of the industry, Samsung debuts the next generation SuperSpeed USB 3.0 flash drive for fast data transfer and backup with backwards compatibility with USB 2.0.
- Samsung BAR MUF-16BA - USB flash drive - 16 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 16 GB
- Enclosure Colour
- Gold
- OS Required
- Linux 2.4 or later, Apple MacOS X 10.4 or later, Microsoft Windows 2000/XP/Vista/7/8/8.1, Windows 10
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Enclosure Colour
- Gold
- Read Rate
- Up to 130 MB/s
- Write Rate
- Up to 15 MB/s
- Interface Type
- USB 3.0
- Shockproof, magnetic-proof, waterproof, X-ray-proof, temperature-proof
- OS Required
- Limited warranty - 5 years
- 12.2 mm
- 40 mm
- 10.92 mm
- 8.9 g
- 0 °C
- 60 °C
