Samsung B2030N 20" 1600 x 900 5MS LCD Monitor
Quicklinx: 7DZNWS00 Mfr#: LS20PUYKF/EN
See rich colours come to life with the Samsung B2030N. It comes in a chic new design that will certainly add a touch of style to wherever you decide to put it. Features such as MagicBright and MagicColour give you more control over what you see, while 4 levels of energy saving gives you even more choice when it comes to watching your carbon footprint.
  • Perfect high speed performance
    With a response time of 5ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes. This stunning, seamless motion imaging presents movies, games, and internet streamed content with precision and without the motion judder, blurring, and ghosting that can occur on a slower monitor, allowing you to enjoy a completely immersive viewing experience.
  • Get into the details
    The differences make all the difference. That's why the Samsung ultra-high 50000:1 Dynamic Contrast ratio automatic backlight adjustment creates deeper, more dramatic dark tones and brighter, more striking light tones. Now you can enjoy images that echo reality with rich, vivid color and brilliant natural intensity. When it comes down to the details, conventional monitors simply pale in comparison.
  • Feel the Effects of Colour
    Enhance images your way using Samsung's advanced ColourEffect feature. Open your eyes to a completely customized viewing experience as you play with photographic effects that match your mood. Choose from Aqua, Sepia, Green and Grayscale to interact with your display in a whole new way – namely, yours.
  • Reduce eyestrain. Enhance your viewing experience
    How do you like to watch movies? Do you like lying down on the couch? Sitting in your favourite chair? Cooking or exercising? Whether you're standing, sitting or lying down, Samsung's Magic Angle makes sure that the movie always takes centre stage. And that you're always comfortable. Wherever you place the Samsung monitor, its 5-mode angle management allows you to extend its viewing angle so the screen always appears as if viewed face-on. So stop craning your neck and start enjoying the movie.
  • Control brightness, conserve energy
    Magic Eco makes saving energy easy. It adjusts Samsung monitor's brightness based on how much energy you want to save. You have four energy saving options to choose from: 100%, 75%, and 50% power consumption as well as ‘power saving off'. If Magic Eco is turned off, you still enjoy the option of using Samsung's Magic Bright feature, engineered to let you manually adjust the screen's brightness. Take the effort out of saving energy and take control with Magic Eco.
Samsung SyncMaster B2030N - LCD monitor - 20"
LCD monitor - 20"
Native Resolution
1600 x 900
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Glossy black
49.2 cm x 17.8 cm x 39.6 cm
4.1 kg
Microsoft Certification
Works with Windows Vista
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, DDC-2B
Display Type
LCD monitor / TFT active matrix
Diagonal Size
20"
Native Resolution
1600 x 900
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Controls & Adjustments
H/V position
MagicAngle, MagicBright 3
Glossy black
4.1 kg
VGA
Mechanical
VESA Mounting Interface
75 x 75 mm
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power Supply
Internal
Power Consumption (Typical)
25 Watt
Power Consumption Stand by / Sleep
0.3 Watt
Shipping Width
56.6 cm
Shipping Depth
13.2 cm
Shipping Height
40.1 cm
Shipping Weight
5.5 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
