Samsung A36 5G 256GB Lavender
Quicklinx: J3DPWS00 Mfr#: SM-A366BLVGEUB
Colours:
  • Android
£345.86 ex VAT
£415.03 inc VAT
Galaxy A36 5G – Awesome AI
Make it picture perfect
Tap away any unwanted parts of your photo and get helpful editing suggestions with the AI-boosted Object Eraser.
Signature style at a tap
With My Filter, creating your own bespoke photo style has never been easier. Using the power of AI, it gathers cues from your previous pics to offer helpful suggestions.
Level up your editing
Whether it’s taking away shadows, unsightly reflections or lens flare, tap Edit Suggestion* to upgrade your photos without fuss. *Edit Suggestion is compatible with JPG, PNG, GIF and MP4 formats. Edit results and quality may vary depending on the photography or filming condition.
Circle it, find it
Instantly search anything you see on your screen using Circle to Search with Google. With a single motion, discover more without needing to switch apps.
*Requires network connection. Availability of search functions and its supported apps may vary by country, language and device. Results may vary depending on visual matches.
Power to do more
Make the most of the Galaxy A36 5G’s Qualcomm SM6475 Processor and enjoy a smoother, quicker performance with sleek graphics as standard.*
*8% CPU improvement from A35 5G.
Unmissable visuals in your pocket
With a slimmer bezel housing a 6.7" FHD+ Super AMOLED screen with 120hz refresh rate and 1200 nits brightness, a truly vivid visual experience is in your hands.
*Improvement from Galaxy A35 5G.
Low light? No problem
Stunning photos and videos, even in low light, are a reality with enhanced nightography. The 50MP Main Camera and new 12MP HDR Selfie Camera capture every detail and hue perfectly, no matter the situation, with videos offering 4x richer colours than previous models.*
The numbers add up
Take advantage of 256GB storage across the latest Galaxy A Series devices. Keep hold and special memories, and there’s no need to worry about space when installing games and apps.
It grows with you
With six generations of guaranteed Galaxy OS updates, you can rely on your Galaxy A Series keeping up with the latest changes from Samsung.
Keeping you covered
Knox Security will stay on top of the latest updates for at least six years, giving you extra peace of mind where it counts . The advanced Theft Protection within One UI 7.0 means your Galaxy A56 5G is automatically locked if theft is suspected through movement or connection status detection.
Sleek, strong, stylish
Featuring a tough frame and glass backplate, the Galaxy A36 5G is as distinctive as it is robust. Tackle the elements With an IP67 Dust and Water Resistance* rating as standard, the Galaxy A Series is the go anywhere, do-anything smartphone you can rely on.
*IP67 rating based on lab test conditions for submersion in up to 1 meter for up to 30 minutes against low water pressure only. Not advised for beach or pool use.
*Updates are controlled by Google who own Android, so updates might not be annually, however it will cover 6 generations worth of upgrades. This can remain as 6 years, as we control Knox security.
