Samsung A26 5G 256GB Mint
Quicklinx: J3DWWS00 Mfr#: SM-A266BLGCEUB
Colours:
  • Android
£259.29 ex VAT
£311.14 inc VAT
Galaxy A26 5G – Awesome AI
Make it picture perfect
Tap away any unwanted parts of your photo and get helpful editing suggestions with the AI boosted Object Eraser.
Signature style at a tap
With My Filter, creating your own bespoke photo style has never been easier. Using the power of AI, it gathers cues from your previous pics to offer helpful suggestions.
Level up your editing
Whether it’s taking away shadows, unsightly reflections or lens flare, tap Edit Suggestion* to upgrade your photos without fuss.
*Edit Suggestion is compatible with JPG, PNG, GIF and MP4 formats. Edit results and quality may vary depending on the photography or filming condition.
Circle it, find it
Instantly search anything you see on your screen using Circle to Search with Google. With a single motion, discover more without needing to switch apps.
*Requires network connection. Availability of search functions and its supported apps may vary by country, language and device. Results may vary depending on visual matches.
Charge right on
A 5000mAh battery* means you can keep on scrolling and creating content, all day, every day.
*Typical value tested under third party lab conditions. Rated minimum capacity is 4905mAh.
Power to do more
Make the most of the Galaxy A26 5G’s Exynos 1380 Processor and enjoy a smooth, quick performance with sleek graphics as standard.
Unmissable visuals in your pocket
With a slimmer bezel housing a 6.7" FHD+ Super AMOLED screen with 120hz refresh rate, a truly vivid visual experience is in your hands.
Low light? No problem
Stunning photos and videos, even in low light, are a reality with enhanced nightography. The 50MP Main Camera captures every detail and hue perfectly, no matter the situation.
The numbers add up
Take advantage of 256GB storage across the latest Galaxy A Series devices. Keep hold and special memories, and there’s no need to worry about space when installing games and apps.
It grows with you
With six generations of guaranteed Galaxy OS updates, you can rely on your Galaxy A Series keeping up with the latest changes from Samsung.
Keeping you covered
Knox Security will stay on top of the latest updates for at least six years, giving you extra peace of mind where it counts . The advanced Theft Protection within One UI 7.0 means your Galaxy A56 5G is automatically locked if theft is suspected through movement or connection status detection.
Sleek, strong, stylish
Featuring a tough frame and glass backplate, the Galaxy A26 5G is as distinctive as it is robust.
*Updates are controlled by Google who own Android, so updates might not be annually, however it will cover 6 generations worth of upgrades. This can remain as 6 years, as we control Knox security
