Reach max performance of PCIe 4.0. Experience longer-lasting, opponent-blasting speed. The in-house controller's smart heat control delivers supreme power efficiency while maintaining ferocious speed and performance, so you can stay at the top of your game.
PCIe 4.0 speed maximized
Huge speed boost, faster random read/write speeds than 980 PRO. Fly high in gaming, video and 3D editing, data analysis, and more. -
Breakthrough power efficiency
More power-efficient performance. Higher performance usually consumes more power. But, 990 PRO uses less power with over 50% improved performance per watt over 980 PRO. This low-power design makes max PCIe 4.0 performance possible with optimal power efficiency. -
Smart thermal solution
Speed beyond the heat. The nickel-coated controller and cutting-edge thermal control algorithm manage heat for unwavering performance. The heat spreader label controls NAND chip heat, while Dynamic Thermal Guard keeps temperatures optimal. -
The champion maker
A more than 55% improvement in random performance enables faster loads for ultimate gaming realism on PS5 and DirectStorage PC games.
- Samsung 990 PRO MZ-V9P2T0BW - SSD - 2 TB - PCIe 4.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- M.2 2280
- Interface
- Data Transfer Rate
- 8 GBps
- Samsung V-NAND 3bit MLC Technology, 2GB LPDDR4 DRAM cache, TRIM support, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, sleep mode, NVMe 2.0, S.M.A.R.T.
- 22 mm x 80 mm x 2.3 mm
- 9 g
- 5-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
- 2.3 mm
- 9 g
Performance
- SSD Endurance
- 1200 TB
- Drive Transfer Rate
- 8 GBps (external)
- Internal Data Rate
- 7450 MBps (read) / 6900 MBps (write)
- 4KB Random Read
- 1400000 IOPS
- 4KB Random Write
- 1550000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- Compatible Bay
- M.2 2280
- Power Consumption
- 5.8 watt (read) , 5.1 watt (write) , 55 mW (idle) , 5 mW (L1.2 mode)
- Software Included
- Samsung Magician Software
- IEEE 1667, FCC, UKCA, cRUus, VCCI, EAC
- Package Details
- Box
- Limited warranty - 5 years / 1200 TBW
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (non-operating)
- 1500 g @ 0.5 ms
- Vibration Tolerance (non-operating)
- 20 g @ 20-2000 Hz
