Samsung 990 PRO SSD NMVE PCIe 4 2TB
Quicklinx: HDQ5WS00 Mfr#: MZ-V9P2T0BW
Form Factor: M.2 2280
Capacity: 2TB, 2TB
Interface: PCI Express 4.0 x4 (NVMe)
Type: Internal SSD
33 In Stock
£141.34 ex VAT
£169.60 inc VAT
Reach max performance of PCIe 4.0. Experience longer-lasting, opponent-blasting speed. The in-house controller's smart heat control delivers supreme power efficiency while maintaining ferocious speed and performance, so you can stay at the top of your game.
  • PCIe 4.0 speed maximized
    Huge speed boost, faster random read/write speeds than 980 PRO. Fly high in gaming, video and 3D editing, data analysis, and more.
  • Breakthrough power efficiency
    More power-efficient performance. Higher performance usually consumes more power. But, 990 PRO uses less power with over 50% improved performance per watt over 980 PRO. This low-power design makes max PCIe 4.0 performance possible with optimal power efficiency.
  • Smart thermal solution
    Speed beyond the heat. The nickel-coated controller and cutting-edge thermal control algorithm manage heat for unwavering performance. The heat spreader label controls NAND chip heat, while Dynamic Thermal Guard keeps temperatures optimal.
  • The champion maker
    A more than 55% improvement in random performance enables faster loads for ultimate gaming realism on PS5 and DirectStorage PC games.
Samsung 990 PRO MZ-V9P2T0BW - SSD - 2 TB - PCIe 4.0 x4 (NVMe)
Solid state drive - internal
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
PCIe 4.0 x4 (NVMe)
Data Transfer Rate
8 GBps
TRIM support, sleep mode, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, Samsung V-NAND 3bit MLC Technology, 2GB LPDDR4 DRAM cache, S.M.A.R.T., NVMe 2.0
22 mm x 80 mm x 2.3 mm
9 g
5-year warranty
2 TB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 4.0 x4 (NVMe)
22 mm
80 mm
2.3 mm
9 g
Performance
SSD Endurance
1200 TB
Drive Transfer Rate
8 GBps (external)
Internal Data Rate
7450 MBps (read) / 6900 MBps (write)
4KB Random Read
1400000 IOPS
4KB Random Write
1550000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
5.8 Watt (read) , 5.1 Watt (write) , 55 mW (idle) , 5 mW (L1.2 mode)
Software Included
Samsung Magician Software
VCCI, FCC, EAC, cRUus, IEEE 1667, UKCA
Package Details
Box
Limited warranty - 5 years / 1200 TBW
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
Capacity: 2TB
Capacity: 2TB
Type: Internal SSD
Brand: Samsung
