Enhanced durability
Equipped with Dynamic Thermal Guard protection, the Samsung 990 PRO ensures optimal performance by preventing overheating, alongside a robust shock and vibration tolerance that safeguards your data during unexpected jolts. -
High-speed performance
Boasting an impressive internal data rate of up to 7450 MBps for reading and 6900 MBps for writing, this solid state drive leverages PCI Express 4.0 x4 (NVMe) interface for swift data transfer, making it ideal for demanding applications and multitasking. -
Advanced security
With 256-bit AES hardware encryption and TCG Opal Encryption, the Samsung 990 PRO offers a secure storage solution, protecting sensitive data against unauthorized access. -
Efficient operation
Features like Device Sleep support and a low power consumption mode ensure the drive operates efficiently, reducing energy costs while maintaining high performance. -
Large capacity and reliability
A generous 4 TB capacity backed by a 1,500,000 hours MTBF rating, coupled with S.M.A.R.T. compliance, provides ample storage for extensive digital libraries with dependable longevity.
- Samsung 990 PRO MZ-V9P4T0BW - SSD - 4 TB - PCIe 4.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 4 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- M.2 2280
- Interface
- Samsung V-NAND 3bit MLC Technology, NVM Express (NVMe) 2.0, 4 GB Low Power DDR4 SDRAM Cache, TRIM support, Garbage Collection technology, Device Sleep support, Dynamic Thermal Guard protection, S.M.A.R.T.
- 22 mm x 80 mm x 2.3 mm
- 9 g
- Capacity
- 4 TB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
- 2.3 mm
- 9 g
Performance
- Internal Data Rate
- 7450 MBps (read) / 6900 MBps (write)
- Maximum 4KB Random Write
- 1550000 IOPS
- Maximum 4KB Random Read
- 1600000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- PCI Express 4.0 x4 (NVMe)
- Compatible Bay
- M.2 2280
- Power Consumption
- 5.5 Watt (average) , 55 mW (idle)
- Software Included
- Samsung Magician Software
- IEEE 1667
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 0.5 ms half-sine
- Shock Tolerance (non-operating)
- 1500 g
