Samsung 990 PRO Heatsink SSD NMVE PCIe 4 2TB
Quicklinx: HDQ3WS00 Mfr#: MZ-V9P2T0GW
Form Factor: M.2 2280
Capacity: 2TB, 2TB
Interface: PCI Express 4.0 x4 (NVMe)
Type: Internal hard drive
More than 50 In Stock
£149.84 ex VAT
£179.80 inc VAT
Reach max performance with PCIe 4.0. Experience longer-lasting, opponent-blasting speed. The in-house controller's smart heat control delivers supreme power efficiency while maintaining ferocious performance that always keeps you at the top of your game.
  • Huge speed boost
    Get random read/write speeds faster than 980 PRO. Experience up to 1550K IOPS, while sequential read/write speeds up to 7450/6900 MB/s reach near the max performance of PCIe 4.0. Fly high in gaming, video editing, 3D modeling, data analysis and more.
  • More power-efficient performance
    Use less power and get more performance. Enjoy up to 50% improved performance per watt over 980 PRO, plus optimal power efficiency with max PCIe 4.0 performance.
  • Smart thermal control
    Samsung's own nickel-coated high-end controller delivers effective thermal control and prevents sudden performance drops from overheating. Play confidently with stable thermal power and minimal fan noise even during heavy-graphic gaming. With its slim size, 990 PRO with Heatsink is a perfect fit for PlayStation 5, desktops and laptops that meet the PCI-SIG D8 standard.
  • The champion maker
    A more than 55% improvement in random performance enables faster loads for an ultimate gaming experience on PS5 and Direct Storage PC games. With RGB LED lights, Heatsink's futuristic design adds style to function.
Samsung 990 PRO MZ-V9P2T0GW - SSD - 2 TB - PCIe 4.0 x4 (NVMe)
Solid state drive - internal
2 TB
Integrated Heatsink
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
M.2 2280
PCIe 4.0 x4 (NVMe)
2 GB Low Power DDR4 SDRAM Cache, Samsung V-NAND 3bit MLC Technology, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, sleep mode, NVMe 2.0, S.M.A.R.T.
24.3 mm x 80 mm x 8.2 mm
28 g
5-year warranty
2 TB
Hardware Encryption
256-bit AES
Integrated Heatsink
M.2 2280
PCIe 4.0 x4 (NVMe)
24.3 mm
80 mm
8.2 mm
28 g
Performance
Internal Data Rate
7450 MBps (read) / 6900 MBps (write)
Maximum 4KB Random Write
1550000 IOPS
Maximum 4KB Random Read
1400000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
5.8 Watt (read) , 5.1 Watt (write) , 55 mW (idle) , 5 mW (L1.2 mode)
Software Included
Samsung Magician Software
IEEE 1667
Package Details
Box
Limited warranty - 5 years / 1200 TBW
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
Capacity: 2TB
Capacity: 2TB
Brand: Samsung
