Reach max performance with PCIe 4.0. Experience longer-lasting, opponent-blasting speed. The in-house controller's smart heat control delivers supreme power efficiency while maintaining ferocious performance that always keeps you at the top of your game.
Huge speed boost
Get random read/write speeds faster than 980 PRO. Experience up to 1550K IOPS, while sequential read/write speeds up to 7450/6900 MB/s reach near the max performance of PCIe 4.0. Fly high in gaming, video editing, 3D modeling, data analysis and more. -
More power-efficient performance
Use less power and get more performance. Enjoy up to 50% improved performance per watt over 980 PRO, plus optimal power efficiency with max PCIe 4.0 performance. -
Smart thermal control
Samsung's own nickel-coated high-end controller delivers effective thermal control and prevents sudden performance drops from overheating. Play confidently with stable thermal power and minimal fan noise even during heavy-graphic gaming. With its slim size, 990 PRO with Heatsink is a perfect fit for PlayStation 5, desktops and laptops that meet the PCI-SIG D8 standard. -
The champion maker
A more than 55% improvement in random performance enables faster loads for an ultimate gaming experience on PS5 and Direct Storage PC games. With RGB LED lights, Heatsink's futuristic design adds style to function.
- Samsung 990 PRO MZ-V9P2T0GW - SSD - 2 TB - PCIe 4.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 2 TB
- Integrated Heatsink
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- M.2 2280
- Interface
- 2 GB Low Power DDR4 SDRAM Cache, Samsung V-NAND 3bit MLC Technology, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, sleep mode, NVMe 2.0, S.M.A.R.T.
- 24.3 mm x 80 mm x 8.2 mm
- 28 g
- 5-year warranty
- Capacity
- 2 TB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- 24.3 mm
- 80 mm
- 8.2 mm
- 28 g
Performance
- Internal Data Rate
- 7450 MBps (read) / 6900 MBps (write)
- Maximum 4KB Random Write
- 1550000 IOPS
- Maximum 4KB Random Read
- 1400000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- PCI Express 4.0 x4 (NVMe)
- Compatible Bay
- M.2 2280
- Power Consumption
- 5.8 Watt (read) , 5.1 Watt (write) , 55 mW (idle) , 5 mW (L1.2 mode)
- Software Included
- Samsung Magician Software
- IEEE 1667
- Package Details
- Box
- Limited warranty - 5 years / 1200 TBW
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- 5 - 95% (non-condensing)
- Shock Tolerance (non-operating)
- 1500 g
- Vibration Tolerance (non-operating)
- 20 g @ 20-2000 Hz
