Samsung 980 PRO Heatsink SSD NMVE PCIe 4 1TB
Quicklinx: HDQ6WS00 Mfr#: MZ-V8P1T0CW
Form Factor: M.2 2280
Capacity: 1TB, 1TB
Interface: PCI Express 4.0 x4 (NVMe)
Type: Internal hard drive
£118.30 ex VAT
£141.96 inc VAT
Unleash the power of the Samsung 980 PRO with Heatsink for next-level computing and gaming. With a PCIe 4.0 NVMe interface, get up to 2x the data transfer rate of PCIe 3.0 while remaining compatible with PCIe 3.0. The integrated heatsink disperses heat to maintain speed, power efficiency, and thermal control, preventing downtime from overheating on Playstation 5 and PCs.
  • Top Speed
    Get read speeds up to 7,000 MB/s with 980 PRO with Heatsink and push the limits of what SSDs can do. Powered by an in-house controller designed to harmonize the flash memory components and the interface for top speed - with a PCIe 4.0 interface that's 2x faster than PCIe 3.0 SSDs and 12x faster than Samsung SATA SSDs - every component of this NVMe SSD is manufactured by Samsung forperformance that lasts.
  • A winning combination
    The 980 PRO with Heatsink delivers an additional layer of thermal control for smart heat management to reduce heat. Achieve fully immersive gameplay with sustained high-performance bandwidth and throughput for heavy-duty applications in gaming, graphics, data analytics, and more. Load games fast, so you can play more and wait less.
  • Smart thermal control
    High-performance SSDs require high-performance thermal control. The 980 PRO with Heatsink uses Samsung's own nickel-coated high-end controller to deliver effective thermal control of the NAND chip. With the added heatsink, play confidently on PlayStation 5 gaming consoles and PC systems without worries of sudden performance drops from overheating.
  • A Perfect Fit for PlayStation 5
    The 980 PRO with Heatsink has a thin 8.6mm housing, which perfectly fits the PlayStation 5. Its slim size and optimized power efficiency are also ideal for building high-performance PC computing and gaming systems.
  • Samsung Magician software
    Unlock the full potential of 980 PRO with Samsung Magician's advanced, yet intuitive optimization tools. Monitor drive health, optimize performance, protect valuable data, and receive important updates with Magician to ensure you're always getting the best performance out of your SSD.
Samsung 980 PRO MZ-V8P1T0CW - SSD - 1 TB - PCIe 4.0 x4 (NVMe)
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
M.2 2280
PCIe 4.0 x4 (NVMe)
Buffer Size
1 GB
NVM Express (NVMe) 1.3c, Low Power DDR4 SDRAM Cache, TRIM support, Auto Garbage Collection Algorithm, sleep mode, integrated heatsink, Intelligent TurboWrite Technology, PS5 compatible, S.M.A.R.T.
24 mm x 80 mm x 8.6 mm
30.5 g
5-year warranty
1 TB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 4.0 x4 (NVMe)
Buffer Size
1 GB
24 mm
80 mm
8.6 mm
30.5 g
Performance
Internal Data Rate
7000 MBps (read) / 5000 MBps (write)
Maximum 4KB Random Write
1000000 IOPS
Maximum 4KB Random Read
1000000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
PCI Express 4.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
6.2 watt (average) , 8.9 watt (maximum) , 35 mW (idle)
Software Included
Samsung Magician Software
IEEE 1667
Package Details
Hanging box
Limited warranty - 5 years
Shock Tolerance (operating)
1500 g @ 0.5 ms
Capacity: 1TB
Capacity: 1TB
Brand: Samsung
