Smart and powerful upgrade: NVMe PCIe 3.0 SSD for gaming and demanding applications.
Plug full power: More than 6.2 times faster than SATA SSDs with read/write speeds up to 3500mbs (500GB variant).
The Samsung Magician software optimises performance for you and keeps the drive up to date with updates.
- Samsung 980 MZ-V8V500BW - SSD - 500 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 500 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- NVM Express (NVMe) 1.4, Samsung V-NAND 3bit MLC Technology, Host Memory Buffer (HMB), Samsung Pablo Controller, TRIM support, Auto Garbage Collection Algorithm, Device Sleep support, Intelligent TurboWrite Technology, state-of-the-art thermal control, S.M.A.R.T.
- 22.15 mm x 80.15 mm x 2.38 mm
- 8 g
- 5-year warranty
- Capacity
- 500 GB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- 22.15 mm
- 80.15 mm
- 2.38 mm
- 8 g
Performance
- SSD Endurance
- 300 TB
- Internal Data Rate
- 3100 MBps (read) / 2600 MBps (write)
- 4KB Random Read
- 17000 IOPS
- 4KB Random Write
- 54000 IOPS
- Maximum 4KB Random Write
- 470000 IOPS
- Maximum 4KB Random Read
- 400000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 4.3 watt (average) , 5.9 watt (maximum) , 0.045 watt (idle)
- Software Included
- Samsung Magician Software
- IEEE 1667
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
