Samsung 970 EVO Plus 1TB M.2 SSD
Quicklinx: F1C3WS00 Mfr#: MZ-V7S1T0BW
Form Factor: M.2 2280
Capacity: 1TB, 1TB
Interface: PCI Express 3.0 x4 (NVMe)
Type: Internal hard drive
More than 50 In Stock
£75.00 ex VAT
£90.00 inc VAT
Standard delivery Delivered within 3-5 working days
Unreal Performance, Realized.
Always Evolving SSD
The ultimate in performance, upgraded. Faster than the 970 EVO, the 970 EVO Plus is powered by the latest V-NAND technology and firmware optimization. It maximizes the potential of NVMe bandwidth for unbeatable computing. In capacities up to 2TB, with reliability of up to 1,200 TBW.
Level up Performance
The 970 EVO Plus reaches sequential read/write speeds up to 3,500/3,300 MB/s, up to 53% faster than the 970 EVO. The latest V-NAND—which brings greater NAND performance and higher power efficiency—along with optimized firmware, a proven Phoenix controller, and Intelligent TurboWrite boost.
Unparalleled Reliability
Achieve a new level of drive confidence. Samsung’s advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable superior heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to minimize performance drops.
  • Always evolving SSD
  • Level up performance
    The 970 EVO Plus reaches sequential read/write speeds up to 3,500/3,300 MB/s, up to 57% faster than the 970 EVO. The latest V-NAND technology - which brings greater NAND performance and higher power efficiency - along with optimized firmware, a Phoenix controller, and Intelligent TurboWrite boost speed.
  • Design flexibility
    The next advancement in NVMe SSD. The 970 EVO Plus fits up to 2TB onto the compact M.2 (2280) form factor, greatly expanding storage capacity and saving space for other components. Samsung's innovative technology empowers you with the capacity to do more and accomplish more.
  • Exceptional endurance
    The new standard in sustainable performance. Get up to 1,200 TBW with a 5-year limited warranty for lasting performance. The 970 EVO Plus provides exceptional endurance powered by the latest V-NAND technology and Samsung's quality.
  • Unparalleled reliability
    Achieve a new level of drive confidence. Samsung's advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable superior heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to minimize performance drops.
  • Samsung Magician
    Advanced drive management made simple. The Samsung Magician software will help you keep an eye on your drive. A suite of user-friendly tools helps keep your drive up to date, monitor drive health and speed, and even boost performance.
Samsung 970 EVO Plus MZ-V7S1T0BW - SSD - 1 TB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
PCIe 3.0 x4 (NVMe)
Buffer Size
1 GB
TRIM support, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, TurboWrite Technology, V-NAND Technology, NVM Express (NVMe) 1.3, Samsung Phoenix Controller, S.M.A.R.T.
22.15 mm x 80.15 mm x 2.38 mm
8 g
5-year warranty
1 TB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
Buffer Size
1 GB
22.15 mm
80.15 mm
2.38 mm
8 g
Performance
SSD Endurance
600 TB
Internal Data Rate
3500 MBps (read) / 3300 MBps (write)
4KB Random Read
19000 IOPS
4KB Random Write
60000 IOPS
Maximum 4KB Random Write
550000 IOPS
Maximum 4KB Random Read
600000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
6 Watt (average) , 9 Watt (maximum) , 30 mW (idle max)
IEEE 1667
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1500 g @ 0.5 ms half-sine
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F1C3 048647
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £68.31
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Capacity: 1TB
Capacity: 1TB
Brand: Samsung
Stock Status: Used Stock
