Unreal Performance, Realized.
Always Evolving SSD
The ultimate in performance, upgraded. Faster than the 970 EVO, the 970 EVO Plus is powered by the latest V-NAND technology and firmware optimization. It maximizes the potential of NVMe bandwidth for unbeatable computing. In capacities up to 2TB, with reliability of up to 1,200 TBW.
Level up Performance
The 970 EVO Plus reaches sequential read/write speeds up to 3,500/3,300 MB/s, up to 53% faster than the 970 EVO. The latest V-NAND—which brings greater NAND performance and higher power efficiency—along with optimized firmware, a proven Phoenix controller, and Intelligent TurboWrite boost.
Unparalleled Reliability
Achieve a new level of drive confidence. Samsung’s advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable superior heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to minimize performance drops.
Always evolving SSD
The ultimate in performance, upgraded. Faster than the 970 EVO, the 970 EVO Plus is powered by the latest V-NAND technology and firmware optimization. It maximizes the potential of NVMe bandwidth for unbeatable computing. -
Level up performance
The 970 EVO Plus reaches sequential read/write speeds up to 3,500/3,300 MB/s, up to 57% faster than the 970 EVO. The latest V-NAND technology - which brings greater NAND performance and higher power efficiency - along with optimized firmware, a Phoenix controller, and Intelligent TurboWrite boost speed. -
Design flexibility
The next advancement in NVMe SSD. The 970 EVO Plus fits up to 2TB onto the compact M.2 (2280) form factor, greatly expanding storage capacity and saving space for other components. Samsung's innovative technology empowers you with the capacity to do more and accomplish more. -
Exceptional endurance
The new standard in sustainable performance. Get up to 1,200 TBW with a 5-year limited warranty for lasting performance. The 970 EVO Plus provides exceptional endurance powered by the latest V-NAND technology and Samsung's quality. -
Unparalleled reliability
Achieve a new level of drive confidence. Samsung's advanced nickel-coated controller and heat spreader on the 970 EVO Plus enable superior heat dissipation. The Dynamic Thermal Guard automatically monitors and maintains optimal operating temperatures to minimize performance drops. -
Samsung Magician
Advanced drive management made simple. The Samsung Magician software will help you keep an eye on your drive. A suite of user-friendly tools helps keep your drive up to date, monitor drive health and speed, and even boost performance.
- Samsung 970 EVO Plus MZ-V7S1T0BW - SSD - 1 TB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 1 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Triple-level cell (TLC)
- Form Factor
- M.2 2280
- Interface
- Buffer Size
- 1 GB
- TRIM support, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, TurboWrite Technology, V-NAND Technology, NVM Express (NVMe) 1.3, Samsung Phoenix Controller, S.M.A.R.T.
- 22.15 mm x 80.15 mm x 2.38 mm
- 8 g
- 5-year warranty
- Capacity
- 1 TB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- Buffer Size
- 1 GB
- 22.15 mm
- 80.15 mm
- 2.38 mm
- 8 g
Performance
- SSD Endurance
- 600 TB
- Internal Data Rate
- 3500 MBps (read) / 3300 MBps (write)
- 4KB Random Read
- 19000 IOPS
- 4KB Random Write
- 60000 IOPS
- Maximum 4KB Random Write
- 550000 IOPS
- Maximum 4KB Random Read
- 600000 IOPS
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 6 Watt (average) , 9 Watt (maximum) , 30 mW (idle max)
- IEEE 1667
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Shock Tolerance (operating)
- 1500 g @ 0.5 ms half-sine
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
F1C3 048647 Condition: Customer return - item has been opened but is in excellent condition |
£60.72 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
