Samsung 9100 PRO, PCIe 5.0, NVMe M.2 SSD, 1TB
Quicklinx: J3T5WS00 Mfr#: MZ-VAP1T0BW
Form Factor: M.2 2280
Type: Solid state drive
Capacity: 1TB, 1TB
20 In Stock
£292.62 ex VAT
£351.14 inc VAT
The Samsung 9100 PRO M.2 1 TB solid state drive delivers performance and reliability for storage needs. With an internal data rate of up to 14700 MBps, this SSD is designed to enhance productivity, ideal for gamers, content creators, and professionals who require high-speed data access. The integrated heatsink ensures efficient thermal management, while features like TRIM support and Auto Garbage Collection Algorithm contribute to the longevity and efficiency of the drive. Operating in a wide temperature range from 0°C to 70°C, the Samsung 9100 PRO is resilient in various environments. It employs Samsung V-NAND TLC Technology and Intelligent TurboWrite 2.0 Technology, allowing for faster data writes and reads. With an endurance of 600 TB, this internal hard drive also supports hardware encryption with AES 256-bit, ensuring data security without compromising performance.
  • High-speed performance
    The Samsung 9100 PRO provides an internal data rate of 14700 MBps, ensuring rapid data access and transfer for demanding applications.
  • Robust endurance
    With an endurance rating of 600 TB, this SSD is engineered for durability, suitable for intensive workloads.
  • Advanced thermal management
    The integrated heatsink dissipates heat, maintaining optimal performance levels and extending the lifespan of the drive.
  • Secure data protection
    Equipped with hardware encryption using 256-bit AES, the Samsung 9100 PRO safeguards sensitive information without sacrificing speed.
  • Efficient data handling
    Features such as TRIM support and Auto Garbage Collection Algorithm contribute to improved drive efficiency and sustained performance over time.
Samsung 9100 PRO MZ-VAP1T0 - SSD - 1 TB - PCI Express 5.0 x4 (NVMe)
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
TRIM support, Auto Garbage Collection Algorithm, Device Sleep support, Samsung V-NAND TLC Technology, integrated heatsink, Intelligent TurboWrite 2.0 Technology, PlayStation compatible, NVMe 2.0, S.M.A.R.T.
Enclosure Colour
22.15 mm x 80.15 mm x 2.38 mm
9 g
5-year warranty
1 TB
Hardware Encryption
256-bit AES
M.2 2280
22.15 mm
80.15 mm
2.38 mm
9 g
Performance
SSD Endurance
600 TB
Internal Data Rate
14700 MBps (read) / 13300 MBps (write)
Maximum 4KB Random Write
2600000 IOPS
Maximum 4KB Random Read
1850000 IOPS
Reliability
MTBF
1.500.000 hours
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
7.6 watt (read) , 7.2 watt (write) , 4 watt (idle) , 3.3 mW (sleep)
Software Included
Samsung Magician Software
IEEE 1667
Enclosure Colour
Package Details
Box
Limited warranty - 5 years / 600 TBW
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
Capacity: 1TB
Capacity: 1TB
Brand: Samsung
