Samsung 90W Combo Power AC/Auto DC/ Air Adapter
Quicklinx: 8D1KWS00 Mfr#: AA-PA3NC90/UK
This 90W combo (power/auto/air) adapter powers your notebook and charges your battery, whether you're at the office, on the road or in the air.
Samsung AA-PA3NC90 - power adapter - AC / car / airplane - 90 Watt
Power adapter - AC / car / airplane - external
Input Voltage
AC 100-240 V
Output Voltage
10 - 30 V
Power Capacity
90 Watt
14.44 cm x 8.36 cm x 2.3 cm
ATIV Book 2; 4; Chromebook Series 5; N145 Plus; N148; N150; N150 Plus; N250 Plus; NC110; NC210; NS310; Series 2; 3; 4; 5; 5 Chromebook; 5 Ultra; 6; 7; 7 Chronos; 9
Input Voltage
AC 100-240 V
Output Voltage
10 - 30 V
Power Capacity
90 Watt
Power cable , Car connection adapter - external , Airplane connection adapter - external
14.44 cm
8.36 cm
2.3 cm
Samsung ATIV Book 2 270E4E, 275E5E , Samsung ATIV Book 4 470R5E , Samsung Chromebook Series 5 XE500C21 , Samsung N145 Plus , Samsung N148 , Samsung N150 , Samsung N150 Plus , Samsung N250 Plus , Samsung NC110 , Samsung NC210 , Samsung NS310 , Samsung Series 2 200B4A A01, 200B4A A02, 200B5A A01, 200B5A A02, 200B5A A03, 200B5AI, 200B5B A01, 200B5B S01, 200B5BI , Samsung Series 3 , Samsung Series 4 400B2B, 400B2B A01, 400B2B A04, 400B2B H01, 400B2BI, 400B4B, 400B4B A01, 400B4B H01, 400B4B S01, 400B4B-H03, 400B4BI, 400B4C, 400B4C A01, 400B5B, 400B5B A01, 400B5B A02, 400B5B A03, 400B5B H01, 400B5B S01, 400B5B S02, 400B5B S03, 400B5BH, 400B5BI, 400B5C, 400B5C A03, 400B5C A04, 400B5C-A01, 400B5C-A02, 410B2B A02 , Samsung Series 5 520U4C, 550P, 550P5C, 550P7C , Samsung Series 5 Chromebook XE550C22 , Samsung Series 5 Ultra 530U3B, 530U3BI, 530U3C, 530U4B, 530U4BH, 530U4BI, 530U4C, 530U4E , Samsung Series 6 600B4B, 600B4B-A01, 600B4BH, 600B4B-H01, 600B4BI, 600B4C, 600B5B, 600B5BH, 600B5B-HC1, 600B5B-HC3, 600B5B-S01, 600B5B-S02, 600B5C, 600B5C-S02, 600B5C-S03 , Samsung Series 7 Slate PC , Samsung Series 7 Chronos 700Z3AH, 700Z3A-S01, 700Z3A-S02, 700Z3A-S03, 700Z3C, 700Z3CH, 700Z3C-S05, 700Z3C-S06, 700Z5A, 700Z5AH, 700Z5AI, 700Z5A-S01, 700Z5A-S02, 700Z5A-S03, 700Z5A-S04, 700Z5A-S05, 700Z5A-S06, 700Z5C, 700Z5CH, 700Z5CI, 700Z7C, 700Z7CH, 700Z7C-S02, 700Z7C-S03, 700Z7C-S04 , Samsung Series 9 900X1A, 900X1A-A01, 900X1B, 900X1B-A01, 900X1B-A02, 900X3A, 900X3A-A01, 900X3A-A02, 900X3A-A03, 900X3A-A04, 900X3A-A05, 900X3A-B01, 900X3A-B02, 900X3A-B03, 900X3A-B04, 900X3A-B05, 900X3A-B0B, 900X3B, 900X3C, 900X3C-A05, 900X3C-A06, 900X3C-AB1, 900X3D, 900X3D-A02, 900X3D-A03, 900X3E, 900X4B, 900X4C, 900X4D, 900X4D-A03
