Optical drive for installation in a mobile computer. Allows you to read and write DVD ± R / RW, CD-R/RW and DVD-RAM discs (without cartridges).
- Manufacturer Samsung
- Model SN-208FB
- Type of equipment DVD ± R / RW, DVD-ROM, CDRW, CD-ROM
- The colors used in the design Black
- Access time DVD-ROM: 150 ms, CD-ROM: 150 ms
- Speed DVD-ROM drive: 8x (10800 KB / sec)
- Speed CD-ROM drive: 24x (3600 KB / s)
- Disc loading mechanism Tray
- Recording techniques Disc-at-once, Track-at-once, Session-at-once, Multisession, Packet writing, RAW writing, Overburn
- Buffer 1024 K, using technology to prevent buffer underrun errors
- Recording speed DVD + R: 8x, DVD + RW: 8x, DVD-R: 8x, DVD-RW: 6x, CD-R: 24x, CD-RW: 24x, DVD + R9 (dual layer): 6x, DVD-R DL (dual layer): 6x, DVD + RAM: 5x
- Interface SATA
- Supported formats DVD-RAM, DVD-ROM, DVD-R, DVD + R, DVD-RW, DVD + RW, CD-DA, CD-ROM, CD-ROM/XA, Photo CD, Multisession, Karaoke CD, Video-CD, CD-I, CD-Extra, CD-R/RW
- Dimensions (width x height x depth) 128 mm x12.7 x127
- Weight 0.15 kg
- Others SpeedPlus power speed technology, double OPC (optimum power control) in DVD + R, SAT (speed adjustment technology)
- Samsung SN-208FB - DVD±RW (±R DL) / DVD-RAM drive - Serial ATA - internal
- DVD±RW (±R DL) / DVD-RAM drive - internal
- Black
- Interface
- Serial ATA
- 12.8 cm x 12.7 cm x 1.27 cm
- 170 g
- Optical Storage
- DVD±RW (±R DL) / DVD-RAM - 5.25" Slim Line
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
- Buffer Underrun Protection
- Buffer Under Run Free Technology
- Media Load Type
- Tray
- Black
- Interface
- Serial ATA
- 12.8 cm
- 12.7 cm
- 1.27 cm
- 170 g
Optical Storage
- Read Speed
- Write Speed
- Supported Media Formats
- CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Mixed-mode CD, Photo CD, Video CD, CD-ROM, DVD-Video
- Supported Media Types
- CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
- Media Load Type
- Tray
- Access Time
- 190 ms (DVD), 190 ms (CD)
- Buffer Size
- 512 KB
- Horizontal/vertical mountable, Speed Adjustment Technology (SAT), Tilt Actuator Compensation (TAC), Double Optimum Power Control, firmware upgradable
- CD-Bridge, Video CD
- 1 x SATA 1.5Gb/s - 7 pin Serial ATA
- Compatible Bay
- 1 x 5.25" Slim Line - front accessible
- Package Type
- Bulk
