Brand
Samsung 870 QVO 8TB 2.5" SSD
Quicklinx: G6XSWS00 Mfr#: MZ-77Q8T0BW
Form Factor: 2.5
Capacity: 8TB
Interface: Serial ATA-600
Type: Internal hard drive
36 In Stock
£441.88 ex VAT
£530.25 inc VAT
The 870 QVO SSD offers an incredible upgrade for everyday PC users who want to ramp-up their desktop PC or laptop to large storage without compromising on performance.
  • Enhanced in everyway
    Achieving the maximum SATA interface limit of high sequential speeds, the 870 QVO features improved random speed and sustained performance compared to the previous 860 QVO. Intelligent TurboWrite accelerates write speeds and maintains long-term high performance with a larger variable buffer.
  • Enjoy max capacity
    With the 870 QVO, users can now enjoy and thrive in the large SSD computing environment with an approachable price.
  • Upgrade with ease
    Upgrading to the 870 QVO is made easy for anyone with a desktop PC or laptop that supports a standard 2.5-inch SATA form factor. Enjoying this SSD is as convenient as plugging in the 870 QVO into a SATA slot.
Samsung 870 QVO MZ-77Q8T0BW - SSD - 8 TB - SATA 6Gb/s
Solid state drive - internal
8 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Quad-level cell (QLC)
2.5"
SATA 6Gb/s
Buffer Size
8 GB
TRIM support, Garbage Collection technology, sleep mode, TurboWrite Technology, V-NAND Technology, Low Power DDR4 SDRAM Cache, Samsung MKX Controller, S.M.A.R.T., 256-bit AES, IEEE 1667
69.85 mm x 100 mm x 6.8 mm
57 g
3-year warranty
8 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
Buffer Size
8 GB
69.85 mm
100 mm
6.8 mm
57 g
Performance
SSD Endurance
2.88 PB
Internal Data Rate
560 MBps (read) / 530 MBps (write)
4KB Random Read
11000 IOPS
4KB Random Write
35000 IOPS
Maximum 4KB Random Write
88000 IOPS
Maximum 4KB Random Read
98000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
3.3 Watt (average) , 5.5 Watt (maximum) , 0.045 Watt (idle)
Limited warranty - 3 years
70 °C
Shock Tolerance (operating)
0.5 ms half-sine
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Form Factor: 2.5
Capacity: 8TB
Brand: Samsung
