Samsung's 860 DCT SSDs deliver optimized performance and value for read-intensive applications like servers and data centers.
Optimized performance
Built to handle the heavier workloads of data center usage, the 860 DCT delivers a high level of sustained performance at a great value for your business. -
Outstanding reliability
The 860 DCT is optimized for server and data center environments by offering reinforced endurance, and low power consumption.
- Samsung 860 DCT MZ-76E960E - SSD - 960 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 960 GB
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- Multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, Auto Garbage Collection Algorithm, V-NAND Technology, Samsung MJX Controller, S.M.A.R.T., 256-bit AES
- 69.85 mm x 100 mm x 6.8 mm
- 51 g
- 3-year warranty
- Capacity
- 960 GB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100 mm
- 6.8 mm
- 51 g
Performance
- SSD Endurance
- 349 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 520 MBps (write)
Reliability
- MTBF
- 1,500,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 2.9 Watt (average) , 1.05 Watt (idle max)
- WWN
- Limited warranty - 3 years
- 0 °C
- 70 °C
